Will it work?
Old Apr 15, 2015 | 08:25 AM
87dimeblazer's Avatar
Default Will it work?
My kids may have helped me make a bid on this converter... Im assuming that since it was bolted to an LT1/4L60E that it will be fine. I have a '99 LS1/4L60E. Any help would be great.
http://www.ebay.com/itm/4L60E-LT1-TORQUE-CONVERTER-2800-3200-TRANS-SPECIALTIES-Z28-TRANS-AM-/161667710663?hash=item25a4257ec7&vxp=mtr
Old Apr 15, 2015 | 09:47 AM
mrvedit's Avatar
Moderator
Nope. Sorry.
An "LT" style converter only works with an "LT" style 4L60E which has a 298mm input shaft.
You need an "LS" converter which fits a (completely different style) 300mm input shaft.
Also, I would avoid any new converter under $450 as they are barely modified versions of GM's V6 converter. There are dozens of threads here about cheap converters failing and ruining the transmission. CircleD makes a good converter for $450. CircleD, Yank and FTI make excellent converters for $700+. Everyone says that spending that kind of money is the best value performance improvement they ever made.
Old Apr 15, 2015 | 09:56 AM
OK, thank you for the help. Looks like i need to start locking my computer. LOL! Costly mistake.
Old Apr 15, 2015 | 11:49 AM
MPTrans.'s Avatar
If it is in fact a Transmission Specialties converter (who are also known performance converter builders), you can call them up for an estimate to fix it for your application. Talk to Ken.
Old Apr 15, 2015 | 12:48 PM
I was able to talk to the seller and retract my bid. I guess I am at least back at the drawing board rather than in the hole.
Old Apr 15, 2015 | 03:36 PM
Circle-D_Brian's Avatar
Like mrvedit said, there have been numerous threads with these types of converters ending badly. I have seen it first hand being a converter cut guy for a long time. The stock converters out of the 4 and 6 cylinders units provide the extra stall speed which is good, but they need some serious reinforcing for a performance application which drives the price up.
-Brian
Old Apr 15, 2015 | 03:40 PM
Thank you for the response. I am looking into the Circle D and Yank Stalls now. I guess you will always get what you pay for.
Old Apr 15, 2015 | 04:52 PM
mrvedit's Avatar
Moderator
Originally Posted by 87dimeblazer
... I guess you will always get what you pay for.
No, but you nearly always have to pay for what you get.
