Problems with built 4l60e
Old Sep 21, 2018 | 11:16 PM
lsx4thewin's Avatar
Default Problems with built 4l60e
I had my stage 2 4l60e built by a local transmission shop back in February of this year. It was built perfect in my eyes. All the bells and whistles you can have on these 4l60s. Problem is with losing gears within a few months. I do have a 12 month/12,000 mile warranty. I know this transmission shop is getting aggravated.
I do race this car time to time but I do not let the transmission shop know this. Im sure they figured it since when I asked them about the rebuild I said I needed it to handle 600hp.
Within 2 weeks of the transmission getting rebuilt I lost 2nd gear again. They fixed it. Paid a shop to remove and reinstall.
March comes around and I kept getting a check engine light for a solenoid issue regarding 3rd gear. But I was told there was nothing wrong with it. I felt like it was starting to slip.
The car ate a lifter a few months ago and I finally got it running again. Problem is my tuner couldn't get 3rd gear to activate no matter what. Which he said tells him something is wrong with 3rd gear. Im going to get it fixed under warranty since I paid extra for it, but should I start looking into swapping in a 4l80? within 2 years im hoping to have twin turbos. Is there a lot of fab work to get the 4l80 to work?
Old Sep 22, 2018 | 04:22 AM
B52bombardier1's Avatar
What vehicle? A 4L80 is physically larger and might require floor sheet metal surgery. Perhaps a different PCM and likely a change to the drive shaft length. A different tune inside the PCM is almost certain to be required.
Rick
Old Sep 22, 2018 | 04:23 PM
lsx4thewin's Avatar
Rick
I have a 2000 trans am
Old Sep 22, 2018 | 05:12 PM
qweedqwag's Avatar
Send it to FLT and be done with it.
Old Sep 22, 2018 | 05:26 PM
98CayenneT/A's Avatar
Local shops are junk, been there until I started building my own.
What kind of times you run ?
Old Sep 22, 2018 | 06:27 PM
lsx4thewin's Avatar
Send in the 4l60?
Old Sep 22, 2018 | 06:30 PM
lsx4thewin's Avatar
I go to Mexico and run on the street. No track times as of now because everytime I try to go something happens with the car. I will be attending some track days hopefully soon! Always wanted to see what times it would make.
Ive heard a lot of bad things with these 4l60s but it was always will people making way more power than me. Im still in the mid 400hp range.
Old Sep 23, 2018 | 07:14 AM
Game ova's Avatar
You're fighting a losing battle with the 4l60. If you just have to have OD then do the 4l80, if not, put a 400 in it and it will be there from now on.
Old Sep 24, 2018 | 07:22 AM
MaroonMonsterLS1's Avatar
Mid 400 range...you'll be just fine with a 60 if the guy with his hands inside it knows what he's doing.
We can all sit here and guess all day, but if you have a warranty, then take it back and see what failed. Then let us know what failed.
Old Sep 24, 2018 | 06:51 PM
lsx4thewin's Avatar
Id like to keep OD which is why I want to go with the 4l80. Ive heard its pretty much bullet proof. But idk how much fab work there is to make it work. Im guessing not much since lots of people go this route.
I took it in today and they're saying its the solenoid. At first they tried to say its the tune and the stall. But my tuner showed me on his computer that he was telling the car to shift into 3rd and it wouldn't at all.
