4l60e binding reverse
Old Nov 30, 2023 | 01:54 PM
  #81
FranksCustomTrans's Avatar
LS1Tech Sponsor
Originally Posted by Mbs1994
It's in without gasket and I take. I'm gonna try Frank's suggestion now of pulling it straight up by the stator. My lunch just ended so it'll be later but I'll take it for now. With the pump sitting in the case it should hold the teflons from expanding right?
Yes on tefs and make it a quick straight upwards thrust.
__________________
Old Nov 30, 2023 | 06:09 PM
  #82
Mbs1994's Avatar
OK so loose half bolts it drops in like butter, tightened it drops to the lip where the seal would be (test fit tightened), still better before but what's your amount of slack you give it? Keep trying till it's tightened and drops in without seal or tap it in?
Old Nov 30, 2023 | 06:27 PM
  #83
Mbs1994's Avatar
Lubed it up and boom its in. I know I've said it a lot but seriously you guys are so amazing and you helped make a strangers freaking day. Bell house and torque converter next. Might start trying to install tonight depending on how long it takes.
Old Nov 30, 2023 | 06:44 PM
  #84
LS1Tech Sponsor
Like I said that alignment method is perfect every time lol
__________________
Old Nov 30, 2023 | 07:10 PM
  #85
Mbs1994's Avatar
Took a few tries but you are a smart feller. Freaking can't believe it but my kit either didn't have them or I lost them but those little orings for the pump bolts and I am not seeing them local
Old Nov 30, 2023 | 08:16 PM
  #86
LS1Tech Sponsor
Do you have a harbor freight there? I am not sure which kit off hand but they have several assorted ORING kits and one of them has the exact ones you need.
Frank
__________________
Old Nov 30, 2023 | 09:20 PM
  #87
Mbs1994's Avatar
Frank
I do fairly close by. I was scared to try anything but the specific ones because I never want to do this again lol. Thought about going back to the same transmission shop I went to before for the teflon and maybe slip the guy a 20 out of appreciation. Dude was gonna give me all the teflons for free last time.
Old Dec 1, 2023 | 07:15 PM
  #88
Mbs1994's Avatar
I'm gonna sound like an amateur and this is gonna be the proof. I have to pull the valve body again. Started making progress, hell was gonna have it assembled tonight. Started hooking up my harness and realize I couldn't because with the vb on things were blocking, pull stuff, put main harness in, reassemble and nope the two metal prong solenoid was backwards. Do it again and okay it's almost done! Lol nooooope because once I got whatever that solenoid is that drops into the pump I can't get the bolt in that sits under the other solenoid. Now I already know what you're gonna say! Just pull it out! We'll that's what I thought too but jokes on me because I installed the retainer in from the underside and it's head is too big to just spin around in that opening. I'm doing it tomorrow. This has been killing me and with stuff in my own personal life I just don't have the mental compacity right now.
Old Dec 1, 2023 | 09:14 PM
  #89
LS1Tech Sponsor
We all have those days , Best to walk away and come back to it.
__________________
Old Dec 6, 2023 | 04:54 PM
  #90
Mbs1994's Avatar
Been a few days. Wife's truck keeps blowing coolant so that's been a ongoing struggle. Finally found coolant under the egr so that's going away. Fixed the solenoid issue on lunch. About to put the servo, bell housing, and converter back. Probably start some other little things before it can go back in just gotta see how the time goes.
Old Dec 6, 2023 | 08:20 PM
  #91
Mbs1994's Avatar
Torque converter won't seat. I think the seal I put on the input shaft is the wrong one.
Old Dec 6, 2023 | 09:00 PM
  #92
LS1Tech Sponsor
Take a photo of the seal
__________________
Old Dec 6, 2023 | 09:16 PM
  #93
Mbs1994's Avatar
I'll get one in the morning since the car isnt where i live unfortunately. It was orange so I assumed it was right but even when I put it on I thought it seemed thicker but just figured maybe because it was new. Converter is in maybe half a inch from the bell housing so still got a lot of room to go. It actually looks like a transmission again so the optimism is high.
Old Dec 6, 2023 | 09:36 PM
  #94
LS1Tech Sponsor
ussually they are black or green and thin
__________________
Old Dec 7, 2023 | 11:31 AM
  #95
Mbs1994's Avatar
It's seated. About 1-1/8 back. Hopefully it'll be done before Monday
Old Dec 7, 2023 | 08:19 PM
  #96
Mbs1994's Avatar
I seriously might do a post install write up of all the freaking little things I've learned from all these damn mistakes to help the next guy. Transmission is like an 8th of an inch off the block and won't go more so I stopped and watched a video to see if maybe I didn't put the flex plate on right or something. Turns out I most likely did because when I was doing it I was rushing and didn't even notice that other little hole that's not for a bolt and don't know if it's lined up with the crank or not. I know that's not my hold up but sure is another surprise that just stopped me for the night.
Old Dec 10, 2023 | 06:14 PM
  #97
Mbs1994's Avatar
Just wanna updated. Haven't had time to try anything. Between snow removal and after hours work it just hasn't happened. Regardless I'll update.
Old Dec 14, 2023 | 08:33 PM
  #98
Mbs1994's Avatar
So been reading and thinking about how to get the trans up flush with the motor. I don't have a second jack to tilt the motor back and definitely have seen not to use the bolts to pull it in. Can I though get it back as close as I can on the dowls and put bolts in just enough to support everything so once I put the jack down the weight of the trans tilts the motor and hopefully give me that angle? It was maybe an 1/8th of an inch from flush.
Side note I was reading some of this thread and I am sorry for all the weird grammar. English is my first language i swear but mobile is not great for me.
Old Dec 14, 2023 | 09:11 PM
  #99
bbond105's Avatar
Once I get the trans close to the dowls I will get a bolt started on each side of the bell housing and tighten them down a little at time while checking that the torque converter will still rotate. If at any point the torque converter stops rotating, you need to stop tightening the bolts and find out why it stopped rotating.
Old Dec 15, 2023 | 07:34 AM
  #100
performabuilt's Avatar
LS1Tech Sponsor
Best advice is slow down, take your time, and make sure your dowel holes and crank pilot hole for the converter are CLEAN. When installing with a jack ive used a 4x4 or other sturdy peice of wood between the trans and jack to help balance the trans. Just keep checking your torque converter and go SLOW checking the torque converter periodically. If anything gets tight then stop and reassess.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
