what stall for my cam/bolt on
Old Jan 1, 2005 | 03:53 AM
boseman350's Avatar
Default what stall for my cam/bolt on
i currently have a VIG 3200
and im getting my tranny rebuilt so im looking at either a VIG 3600 - 3800 or even the 4000 basically the same thing. Its a daily driver w/ 3:23 gears and i mainly want a good drag strip verter compaired to a highway roll car
havea 224 cam and almost all the bolt ones........
what u think ????
Old Jan 1, 2005 | 07:06 PM
4mula's Avatar
what u think ????
vig veters stall higer than what they are rated.
the one you have is fine.
Old Jan 1, 2005 | 07:39 PM
Shinsetsu's Avatar
wanna sell the 3200 ?
Old Jan 1, 2005 | 07:50 PM
BriancWS6's Avatar
what u think ????
Well, in my opinion if the trannys out and your already having thoughts of going bigger, now is the perfect time to do it rather than having to pull it all apart again later. Plus, if you decide to go with a bigger cam in the future, you'll have the converter to support it. I'm planning on a TCI 4400 over the spring/summer to go with my TSP MS3. 4mula is right about the vig being underrated, but I think upgrading now is the logical thing to do. But if you think the 224 will be the only cam you'll have, then I agree with 4mula that it's fine. Just My .02
Old Jan 1, 2005 | 08:16 PM
A3Z28's Avatar
i say you should try a YANK PT4200 OR 4400 for your setup, it will give you the best results for your setup. TCI or Vig either one don't come anywhere close to the YANK verters. get a YANK PT4200 and be done with it.
Old Jan 1, 2005 | 09:45 PM
boseman350's Avatar
my mechanic says go 4 k stall but im leaning toward a 3600 just a lil more andwill work well w/ my med size cam............ btw im leaving things alone for a while untill its time for a motor rebuild/upgrade 408 only thing i might do is step up to 3:42's
Old Jan 1, 2005 | 09:48 PM
boseman350's Avatar
gimmie a good offer on my convertor n i might consider selling it ill be getting the rebuild in 2-3 months
Old Jan 1, 2005 | 10:58 PM
A3Z28's Avatar
i'll give you $300 and a used comp cam 224/228 for it
Old Jan 2, 2005 | 09:18 PM
boseman350's Avatar
if i didnt have a cam id go for it...... Prolly going w/ a 4k stall
Old Jan 3, 2005 | 07:11 PM
A3Z28's Avatar
that's cool man...i'd personally go with the PT4200 from Yank for your setup, you wouldn't regret it at all. the PT converters are the best all out drag verters around for a 4L60E
Old Jan 3, 2005 | 08:33 PM
CamaroCain's Avatar
no more PT4200, if you want a PT get a 4000, if you had a huge cam then the 4400 would be better but not with 3.23 gears IMO. If you go Vig i wouldnt go over a 3600, 3600+ I would definately go with a YANK With a small cam like you have and 3.23 gears I would go 3500-3800 stall.
Old Jan 3, 2005 | 10:32 PM
A3Z28's Avatar
i would definatly upgrade to atleast 3.42 gears also, i went from 3.23 to 3.42 with the same stall and dropped .45 in the 1/4. went from 3.42 to 4.10 and it got plain nasty.
Old Jan 4, 2005 | 07:42 AM
BAIN's Avatar
In your oppinion maybe, but whatever floats your boat
Old Jan 4, 2005 | 04:25 PM
98TAauto's Avatar
i have the vig3600 and with 3.23's and a 224 cam it ran 11.5@117 which wasnt to shabby for 4 passes. I ordered a vig3600 about 4 years ago and i know everyone says they stall higher than rated. But on atap mine flashes to 3650-3700.. so it wasnt that much higher than rated.
If I started over again, i'd maybe try a PT4000 with it since I think that yanks have a tad more MPH. But the vigs a FREAK off the line
