YANK'S new line of transmission crossmembers
Yank has expanded and redesigned it's transmission crossmember line to 5 models for 98-02 f-body, with new lower pricing!
CHECK THEM OUT www.converter.cc in the drive line section
Thank's for looking!
Mike
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Mike
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I tried that, but can't find any "driveline section".
Just converters by-vehicle and the wizard thing.
Are any of these crossmembers the kind that let
you relocate the torque arm off the tailshaft, but
still use stock style mount inserts (I have a Random
Tech arm waiting to go on)?
Jimmy:
Yes, it gets it off the tailshaft and it did not need any other parts to work. I have a BMR TA and had to cut about a 1/2" off the forward end to make it fit. I had the original design and it worked great (now sitting in my basement since my conversion to M6). Street traction felt better and no worrying at the track that you'll bust the tailshaft.
Kleeborp the Moderator™
Nice...I noticed BMR is now making one, and was wondering if you still did. Are people still having to cut off a little off the snout of the Torque Arms? I have a G2 arm on the way, and with how much money I paid for it, I'd really like to not have to cut it, but will if need be.
Is there any way you could make the link less obscure on your page? It took me a while to find it...
Either way, this is going to be mine in a little while.
Oh, and what is this snout hitting that requires cutting? Just curious...I've never messed around with my tranny cross member.
Originally Posted by WILWAXU
LG G2 arm will not work with the Yank crossmember.
Randum Tech works well though![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I also had to trim the TA a little. Most arms stick out past the bushing, even at full extenstion. You have to trim some of that off, ~1/2"
Damn...that really sucks. I don't want to have to send back this torque arm just so I can use it...maybe I'll just learn to live with broken tailshafts.
Moderator
For some reason, above the Vette picture I have only
a busted-link box (there's another on the left side too,
but the rest of the page's images & links work). Can
someone post the driveline link-target for me?
Moderator
Originally Posted by MeentSS02
Any insight into why this is? I just don't see how it would work mounted to the tailshaft but not to this piece?
From what I understand you do not have to trim the TA or anything else to use the BMR crossmember.
http://www.converter.cc/drivetrain.htm
Originally Posted by DAVE AT YANK.
Here is the direct link to the new page on the crossmembers.
Shawn
Moderator
Originally Posted by Yank
We have redesigned the crossmembers to work with the most popular torque arms.
no mods are requiered.
They are not the same as our early style, they are lighter and stronger than any other version on the market
How much does it weigh compared to the "other version on the market" (BMR) and how do you know it is stronger? Was there a test performed to support this?
When will these be available?
Thanks
John
We have sold over 125 of these and there are many cars that have run our 350/400 conversion kits since 1999 all of these use or torque mount system
I have owned a race chassis shop and have 15 years in chassis fab.
Our orginal design of crossmember was taken to BMR back in 1999
an was COPIED, but shortly after that we changed our design to better support the higher power levels
There is no torque load applied to the transmission case or rear mount, all energy is send to the chassis, this allows the front body to lift and plant the rear tires.
an added feature is that on cornering that the rear will stay in place better and not push the trans to the side and change rear alignment
