How much HP do you lose when you add a stall?
hey guys i was just wondoring if or has anyone lost hp when they added a torque converter? i see many guys pushing around 370-380rwhp with a stall thats 3000+. correct me if im wrong but do you really lose hp when you add a stall? if you do, how much do you lose?
Originally Posted by Yank
Here is a test showing our st2600 and ss3200 to the stock converter
you can see that a gain in HP (bigger with the ss3200) over the stock converter not a loss!
this is a Yank converter test at WOT in 3th gear with 3.73 from a dead stop
I had a loss of 40 RWHP between locked and unlocked. The car feels WAY better though. All of my A4 buds LOVE how the car feels and swear I have more mods' than what I do, just from the converter. From what I understand, like was said before, bench racing dyno sheets isn' t necessarily a reflection of the benefit of a TC.
Just my .02
Just my .02
from 750 to 4250 blue line and from 750 to 2850 on the red line is the STR at work, after that point the design efficiency rate will take over till you reach max RPM
the numbers on after Torque mult. stage are the true power that is passing thru the converter.
A converter is lighter, so the engine will accelerate easier/quicker. And the converter will allow the engine to spend more time in the powerband so the car is quicker. Both give the illusion of more HP, but put the car on a dyno and the RWHP should be less or at the very best the same with a stall.
ls1650, you will lose some HP, but it is well worth the trade off.
here you go. my 00 formula stock vs yank py3400e converter unlocked 3.23 gears.
2nd gear stock was 10 mph (700 rpm)start. yank was 15 mph (1000 rpm) start due to blowing the tires off.
same but in 3rd gear
Moderator
You gain power by being in a better place (RPM). You
lose power by any degradation in efficiency vs the old
converter. Converters vary pretty widely in efficiency
delivered, both peak and the profile of it. Yank's better
converters exceed stock efficiency even while running
higher stall speeds. But I've seen dyno curves from some
converters, that deliver pretty poor efficiency below peak.
You really want to know more than most vendors will tell
or guarantee. I wish more of them would publish dyno data
like Yank's.
The Pro Torque guys are pretty much old-school as near
as I can tell, I hit them up a couple years back just 'cause
they were a local operation but they weren't even doing
lockup converters then. So I wouldn't consider them to be
a good example, and you (MattZ28) might want to try
another converter with more development behind it. The
loss in trap suggests a poor efficiency, or at least a stall
mismatched to your powerband (if your HP is fading before
peak efficiency comes on, net loss perhaps).
like Yank's.
Originally Posted by MattZ28
I went from 13.2 @ 105 1.92 to 13.1 @ 102 1.80-1.84 60' with a 3200 Pro Torque 10.5" converter. I also added an aluminum driveshaft so I don't understand
What gears do you have?
Maybe your running to tall a tire, might want to try the 275/50/15's next time?
