Estimated top speed with th350?
Old May 23, 2006 | 10:48 PM
94 z28 A4's Avatar
Default Estimated top speed with th350?
I was wanting to know close to what my top speed would
be with a th350 and 3.73's ? Thanks
Old May 23, 2006 | 11:08 PM
Strahley's Avatar
Also depends on your rear tire and rev limit
Here's a good calculator to use. Keep in mind you will lose a couple mph from what this calculator says, due to the converter slippage
http://www.f-body.org/gears/
Old May 24, 2006 | 09:39 AM
jimmyblue's Avatar
Moderator
Put your 4L60E in 3rd / D, and find out; same 1:1 ratio. Of
course finding the right road for this might be problematic.
Old May 24, 2006 | 11:02 AM
Zombie's Avatar
If your rev limit is 7000 rpms, just run it to 3500 rpms, note the speed and multiply by 2.
Old May 24, 2006 | 02:33 PM
jimmyblue's Avatar
Moderator
You're no fun.
Some difference to be found in the converter slip, it
will tighten up more at the top end of the RPM range.
And no lockup on the TH350, though there is a TH350C
(but whether it's suitable for performance uses I couldn't
say)
Old May 24, 2006 | 09:44 PM
94 z28 A4's Avatar
well when i put my car in 3rd/ D it is doing 95mph at like 5200 rpms.
i know if i get a th350 i should be able to go faster than 95 mph?
Old May 24, 2006 | 09:58 PM
MrBill97396's Avatar
if you want more top speed just get overdrive with it. It will cost more but you will be happy or get a 200r4 just be ready to spend more
Old May 24, 2006 | 10:04 PM
94 z28 A4's Avatar
i found a th350 today that comes with trans. torque
converter, trans.cooler,dipstick tube,detent cable,fluid
for only $839.99 Also would i have to get one that has
a 9'' tailshaft?
Old May 24, 2006 | 10:08 PM
BlackHawk T/A's Avatar
a 9'' tailshaft?
You know for a price like that the trans and the converter are going to be budget "stock" type parts that won't take the heavy abuse we put these cars through. You really get what you pay for...
My .02
Old May 24, 2006 | 10:28 PM
ZTwentyAteU's Avatar
HOw many ponies you have have a lot to do with it. My car with 3.23s does 135 in 3rd. Don't forget the turbo350 has a higher(numerically) first and second gear, I'd say you could still do about 130. with My old chevelle with a .40 over 350, 3.55s and a turbo350 I got clocked at 138mph. so its not out of the question.
Anything over the speed you hit at the dragstrip is useless anyways....
Old May 24, 2006 | 10:50 PM
94 z28 A4's Avatar
Does that mean you can wind it out more in 1st and 2nd?
Old May 25, 2006 | 11:50 AM
396D1SS's Avatar
what kind of power are you making to need a th350?
Old May 25, 2006 | 12:42 PM
Strahley's Avatar
Not always about big power to need a th350. Some people (myself included) like to know the tranny won't take a dump anytime soon. Now if he was wanting a th400/PG then I would probably ask the same thing you did
Old May 25, 2006 | 10:38 PM
revtime's Avatar
I am running a Rossler TH400 Terminator 2 with a JW ultrabell, T brake, RMVB and its behind a stock internal LT1 with 160k and bolt ons.
I have the manifold plumbed for a Direct Port and forged 383 plans so I am building for the future.
Knowing that at this moment that there is nothing my engine can do to hurt this tranny is comforting though.
