going from 2:73 to 3:73...worth it?
Old Jul 13, 2006 | 02:44 PM
  #141
Sunset'01Z's Avatar
oh i could only imagine..
Old Jul 13, 2006 | 02:45 PM
  #142
monicaz28's Avatar
Originally Posted by ChocoTaco369
never said they were THE worst economical mod. one of the worst though, definitely. most people will see a large drop in mpg with gears than any other mod unless they're all city drivers and never see over 55mph. it doesn't take a genius to know that more rpms = less gas mileage. i know everyone in this world wasn't born with common sense but i take pride in being one of the ones that was and understanding these things.
You completely just contradicted yourself.
I didn't lose nearly as much mpg from changing gears from 3.23's to 4.10's as I did from my cam. And I see all kinds of highway and city driving.
i get all my information from users and common sense
Now I understand why you keep talking out of your ***.
Old Jul 13, 2006 | 03:16 PM
  #143
s346k's Avatar
chocotaco...if you're so enriched with common sense, i guess you'd know that a steeper gear in some cases (driver dependent) will BOOST in town mileage. when it's easier for the car to accelerate, less fuel is needed to achieve x speed. you'd also know that an engine with a load on it @ 2,500 is burning more fuel than an engine easily operating at 3,000 rpm. however, you've already absorbed this information from "users and common sense"....but i don't see experience in your crudentials. hmm...that's odd. you're a fountain of information - as long as it has previously been posted on ls1tech, go figure.
/rant
Old Jul 13, 2006 | 03:58 PM
  #144
jmm98LS1's Avatar
/rant
EXACTLY!!! I went from 3.08's to 3.42's in my daily driver truck and my fuel mileage improved 17%. My cruising rpm went up from 2100 to 2600. Lower rpm does not = less fuel burned.......better efficiency = less fuel burned. I'm gonna go look for some of that common sense we all seem to be missing........
Old Jul 13, 2006 | 04:53 PM
  #145
GoFast908Z's Avatar
so has anyone figured out what is the most effecient rpm for crusing?
I'm sure its different for A4 M6
Old Jul 13, 2006 | 05:23 PM
  #146
Sunset'01Z's Avatar
i doubt it, since it's the same motor
Old Jul 13, 2006 | 08:36 PM
  #147
ChocoTaco369's Avatar
Tech Resident
/rant
yea, 3.08's are actually the best gear for f-bodies in MOST situations. 3.08's will yield better mileage than 2.73's in city driving and get similar mileage on the highway that simply won't be enough to offset the gains in city. i never contradicted myself in anything. gears may not be the absolute worst mod you can do. or maybe it can be. if you put a MS4 in with shitty made heads, super high compression and a bad tune, you'll be pulling much worse mpg than gears. or, you can get a moderate cam, a nice set of heads, shoot for a lower compression and have your car tuned very well. that could very well result in much fuel savings over gears. you all are reading into things WAY too much and reading what YOU want to believe and putting words i MY mouth.
Old Jul 13, 2006 | 09:39 PM
  #148
SVT THIS's Avatar
Having an LS1, wanting it to be fast AND having good fuel mileage is like training a kid with Down's Syndrome to be a mechanical engineer-it's just not gonna happen.
Old Jul 13, 2006 | 11:07 PM
  #149
THE LAST Z's Avatar
Jesus Christ ChocoTaco369!!!
2.73 gears...fuel mileage...no gains from this, no gains from that... You made me sick just reading your posts! Why the **** did you buy the car in the first place?
Old Jul 14, 2006 | 12:58 AM
  #150
1fastz's Avatar
chocotaco is......everywhere
Old Jul 14, 2006 | 01:19 AM
  #151
burnzilla's Avatar
2.73's suck big donkey ****.
Old Jul 14, 2006 | 02:18 AM
  #152
Cop Car's Avatar
Originally Posted by Sunset'01Z
just to let you know, this is not at all the prefered order of upgrades. FIRST lid and catback, then stall, then rest of bolt-ons including headers and y/mid pipes and suspension, and then gears if you want to and have 600 bucks that you dont care about pissing away because if you go this far you may as well buy a 12 bolt, then h/c/intake(pre-2001 guys).
if you guys dont think this is right, look at this thread:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/361959-so-you-wanna-fast.html
if you have a 2.73 car, the upgrade that will give you the best net at the track and at the street is a 3.23 or higher rear gear. my friends (identity witheld) slow *** pewter peice of stock ***** ran a 14.1 @ slow with 2.73 rear gear. my stock 3.23 car of the same year ran a 13.2 @ 104. gears give you the best feel and gain, lids are cheap, thats why its second, LTs are third because they are somewhat more complicated, more expensive, and after you have had the car for a while, you can do them yourself. a stall is last becuase on a car you have to drive all the time #1 it will SLAUGHTER your intown milage, AND #2 all you will do on the street is spin unless you have sticky tires (translation, expensive not very long lasting tires). yeah, stalls are awesome, but when a 1500 stall will spin the tires on the street all you are doing is creating a nice smoke show for people.
why would you buy a catback just to replace it later? makie no sensie also, when people are doing wheels up runs in the 9s on mildy modified 10 bolts there is no reason to waste 1500 on a used rear end, expecialy when you are arguing about 600. i have a logic book i can send you if you would like
Old Jul 14, 2006 | 05:07 AM
  #153
BlackHawk T/A's Avatar
Wow some people can't read...I wouldn't say that without having personal experience first.
Old Jul 14, 2006 | 07:51 AM
  #154
Tech Resident
WHAT THE **** ARE YOU PEOPLE TALKING ABOUT? did you even READ the posts before you opened your mouths? his car is STALLED! gears will net him .1-.2 off his quarter IF HE CAN HOOK UP, which will be a helluva lot harder since 3.73's will make his car a bitch to launch. don't open your big mouths before you read his mods. you're gonna spend $500 on gears, sacrifice the strength of your rear and lose 3mpg to go a tenth faster? i said that's a waste, get headers instead. you think i'm wrong? fine, but **** away your own money.
and for your information, i bought the car because it has 350hp and gets 22mpg. i can afford it. if it would have gotten 15mpg i never would have bought it. 22mpg is good mileage. these cars CAN BE very economical compared to some cars out there, and gets better mpg than nearly every V8.
Old Jul 14, 2006 | 07:57 AM
  #155
Tech Resident
lol the funny part is the guy already has a stall in his car. these people are criticizing my posts and they don't even know the reason why i'm saying what i'm saying or the thread starter's mods. i'm all for getting gears in an M6 car. i'm against getting gears in an A4 car that has been stalled. the gains just aren't there once it's stalled. the stall bypasses the very RPM range the gears were intended to pull you through faster making the gears in the end practically useless.
Old Jul 14, 2006 | 08:36 AM
  #156
monicaz28's Avatar
Actually, there is quite a difference here. This is one of those things that does just take a little common sense. Think for a second. Let's put 3.73's in both an a4 car and an m6 car and say cruising speed is 70. Now in the a4, you're going to be turning about 2400 rpm's (assuming your converter is locked) and in an m6, you'll be closer to 1700 rpm's (assuming you're in 6th gear). Now that's a pretty big difference in my book.
Old Jul 14, 2006 | 09:55 AM
  #157
s346k's Avatar
why do you have to hate on the slow cars?
Old Jul 14, 2006 | 09:56 AM
  #158
jmm98LS1's Avatar
Dear God this thread has been thoroughly hijacked and gotten out of control! There's over 150 replies (most of which are from Choco ) and only 1 is from the original poster!.........
Originally Posted by redformulaws6
so the new question is should i instead get slp's long tube headers with slp y pipe instead of the 3:73's......
redformulaws6: Yes, I think you would be better off with longtubes and y-pipe (although not slp, pacesetters are a better choice) than 3.73's at this point. Judging by your first post, you're concerned with making et improvements.....then I would suggest that the next thing(s) on your mod list after headers would be 3.73's and sticky tires.
Chocotaco:
1. This is your first "muscle" car, and first LS1
2. You haven't had it very long
3. You only have a lid, catback and wheels
4. You don't have a cam, heads, headers, a stall or 3:73 gears and it's very apparent by your posts you have little to no experience with any of these mods.
5. Nobody is saying your not trying to help out, but the reason people criticize your posts is because of how adamant you are about mods that you have limited experience with.....mmmmk?
Now everyone play nice, we're all friends here.....well, mostly.
Old Jul 14, 2006 | 10:14 AM
  #159
monicaz28's Avatar
Originally Posted by jmm98LS1
Chocotaco:
Exactly, when you have limited experience you should be more open to what people WITH experience say....
I didn't put 4.10's in my car until after I had gotten a cam, intake, tb, headers, exhaust, and stall.... Just do all that at one time and be done with it!
Old Jul 14, 2006 | 02:22 PM
  #160
BurtReynolds's Avatar
hello.I have 2.73 in my car and im going to change the m to 3.42 0r 373.I like the 273 for cruising.but dont like the launch or the long as 2nd gear.@ tenths is preety good.wouldnt that be a 2 car lead if say you and another ls1 ran the same time.honestly I dont think nobody got this cars to save gas.
