Local Shop to build Stall?
easiest part. At least "close enough". Now if
you want to specify a particular STR along
with it, the builder has to know what to mix-
n-match, stator / pump / turbine. Add a demand
for any particular level of efficiency, enjoy the
blank look. Ask for a lockup clutch you can
beat like a two dollar ***** and still respect
in the morning, at a 10" diameter, and that
should be interesting.
Fuddle cost me a little over $500 in the end,
for this degree of specificity and pretty much
hit it ("only" got 96% on the efficiency). And
the install was a whole 'nother $400 deal.
Figure a straight tranny shop, maybe $300
for R&R and a LS1 converter anywhere from
$350 on up, a SBC converter w/o lockup from
$150 or so in a performance grade, where
does this proposed piece of hardware put
you? Trust these guys for warranty?
They have been sued and been to court over several raw deals in oklahoma. Trending Topics
Chad
them on a 10" 2800-3000 stall its under $300.00 and they
gauranteee it for 90 days they are in okc i think on reno.. I
doubt if rpm was goingto build that for yah in house anyways....
zaine has a 4000 fuddle stall on his car and he got on it a bit before
we stumbled around putting struts on his wifes car. His 4,000 fuddle
stall rocks and he can still drive it around like a normal ride.. i had a
tci 3500 and it came loose after 7 monthsof semi abusive driving.
im either going vigilante or fuddle
if you need a trans rebuilt im going to A SHIFT ABOVE the guy there
named andy knows his stuff! hes right off of council by the home
of the whopper. hopefully hell have mine built by the months end
Also, can they test it on a special dyno? Very few have that kind of equipment, and one of them is a sponsor here.
