This is whats needed for the 4l60e to 4l80e swap!
Old 01-14-2015, 02:36 AM
  #321
95z283406's Avatar
Will I have to use a new converter? Considering just tossing in the core I found for now and rebuilding it once I pull the engine. That way i am not running a stall on a stock engine with potential seal leaks.
Old 01-27-2015, 06:23 PM
  #322
95z283406's Avatar
Default Considering swap to 80
I have a 95 z28 im considering converting to the 80, im currently rebuilding the motor and dont want to have a gutless pig that is a 4l60e behind my power plant. But i dont see on pcmforless or on tunedbyfrost where it has a pcm tune for my year model. Would I need my pcm tuned or flashed to operate the 80? Its an obd1 car even tho it has the 16 pin obd2 port.
Old 02-07-2015, 10:11 PM
  #323
chevyforlife's Avatar
Anyone have the part number for the lokar dipstick tube? Iooked on summit but couldn't find one for the 4l80
Thanks
Old 02-24-2015, 09:25 AM
  #324
comatoastWS6's Avatar
Originally Posted by ez2cdave
Their website has changed . . .
http://www.pcmofnc.com/
Product Code: P-120018 4L80 Conversion Harness
http://www.pcmofnc.com/index.php/per...ersion-harness
What is the difference between this and the speartech harness?
Old 02-24-2015, 12:00 PM
  #325
Moderator
mrvedit's Avatar
Thanks
Search ebay for "4l80e dipstick". There are different Lokar models (e.g. silver and black) with links to the Summit website. Also some alternatives to consider.
Old 02-24-2015, 07:58 PM
  #326
MrBlueDevil14's Avatar
Thanks
LOK-TD34L80FM36
http://www.summitracing.com/parts/LOK-TD34L80FM36
I just ordered it 2 weeks ago
Old 11-18-2015, 03:07 PM
  #327
Robert.P23's Avatar
Default 4l80e swap help me!!!
Hi I'm Robert, I need help figuring out this stuff! I don't fool around with the ecm side of trucks and need to figure out how to do the segment swap as cheap as possible. I have a 97 chevy z71 with the 5.7 I put the 4l80e in and repinned the plug to work. Please let me know what needs to be done from here.
Thanks, Robert.
P.s. I do not have the tuner or whatever its called.
Old 09-05-2016, 06:17 PM
  #328
ss performance's Avatar
I'm doing the swap into my 02 Camaro. My trans didn't come with a dust cover.
I have found a GM 4L80E dust cover 19259119. It is listed as cast aluminum for LS applications.
Do I need this one or can I use the stamped steel one off a TH400?
Thanks
Old 10-26-2016, 04:39 PM
  #329
Narxoleptic's Avatar
My donor engine/harness is a 2005 Tahoe 5.3. I am swapping to a 4L80 when it goes into the old truck (see profile pic). Are there certain years of the 4L80 that I need to be looking to buy?
I have the Speartech swap electronics on my list and the flexplate and spacer and all that. Just making sure i dont buy one too old or new that i cant use without serious modification to electronics.
Thanks!
Old 01-26-2017, 07:20 AM
  #330
Turbo Trans's Avatar
Default 4L80e Swop FlyWheel
I used the Flywheel from a 2500 has burner 4.8 to 6.0 it had the spacer built in. I also used the stock converter for now worked fine and a cheap route to go.
Originally Posted by Z'mnypit
If im not mistaken you can buy a 4l80e converter and run a crank spacer so the LS1 flexplate will work. You will only use three of mounting points like the LS1 does though. Either way you will have to buy a converter so why not buy one thats made to fit. The 4l60e converter will NOT fit the 4l80e. The input shafts are different.
I am not running a spacer.
You shouldnt need the wiring harness from speartech, at least not all of it. The 4l80e has two VSS sensors so in order to get the speedo to work you should only need the VSS sensor harness from them. The rest should be done with the TCI controller.
Old 02-09-2017, 08:59 PM
  #331
merim123's Avatar
If the fbody is a 4l60e does it still need tp be sent to hpt for mod or is that now possible directly in the software
Old 02-10-2017, 12:35 PM
  #332
MY_2K_Z's Avatar
In 3.0 you can segment swap it your self
Old 03-09-2017, 01:35 PM
  #333
irocbrninrubber's Avatar
Everything is sold. Thanks
Old 10-12-2017, 10:07 PM
  #334
tlowenthal66's Avatar
Default Pictures
Do any of you have pictures of the 4L80E Transmission mount attached to the transmission?
Old 10-13-2017, 12:18 AM
  #335
clinebarger's Avatar
Use the 4L60E mount, Mine is turned around using a UMI Crossmember.
Old 10-13-2017, 12:30 AM
  #336
The following users liked this post:
JoshuaGrooms83 (07-27-2022)
Old 10-13-2017, 07:39 AM
  #337
01ssreda4's Avatar
Can take the 4l60e dipstick, mark and measure the tube, cut out a section and replace it with 3/4 heater hose = homemade flexible dipstick.
Rear AN clearance clearance problems
Old 01-10-2021, 09:03 AM
  #338
Nate6.0's Avatar
Originally Posted by DogNutz
Just run a truck PCM and recalibrate it for your car! Goodbye wiring adapter!
quick question...97 Tahoe black box PCM with 4l80 swap in 95 1 ton. Bought & have the 4l60 to 4l80 harness and need to know 2 things:
1) what pins do the 2 additional vss wires need to go to in the black box pcm?
2) can black box pcm be flashed for 4l80 program?
Old 07-05-2022, 10:15 PM
  #339
54inches's Avatar
So, I have a 2005 2wd CCSB that I swapped in a 2005 LQ4 and a rebuilt 60e.
I just ran across a 2003 2500 2wd Van with a 6.0 80e and a Dana 60 rear running & driving for stupid cheap.
I have had future plans to swap in an 80e.
I have read all the swap threads and understand the wiring needed.
Would it be advantageous to take the ECM or any other computer out of the van and use it in my truck for the 80e swap?
I would think so, so there is no need to change files into my computer, but I never hear anyone talk about it.
Thanks in advance!
Old 07-14-2022, 07:44 AM
  #340
css
css's Avatar
Originally Posted by slow67
A transgo -2 kit is for full auto, -3 is for full manual (I don't think the hydraulic full manual kit works very well). I can make a '98 PCM control a 4L80E for full auto (with some tuning), thats no problem. PM me for those details.
Hey. whats the details on doing this. I'm putting a 4l80e in my 97 tahoe have read alot but for years 99 and up. From what I've come up with is changing one wire on plug and 2 wires not being used. let me know Thanks
Quick Reply: This is whats needed for the 4l60e to 4l80e swap!
