Flywheel with TH-350
Old Nov 29, 2002 | 08:56 PM
V6 Bird's Avatar
Default Flywheel with TH-350
What flywheel is everyone using? Are you drilling your stock ones? All help is apprecaited. i know i can use the tailshaft off of a 700r4 to use my stock TA mount. Im curious onteh flexplate though.
Old Nov 29, 2002 | 09:23 PM
Nine Finger 02 Z28's Avatar
Default Re: Flywheel with TH-350
I just bought one for a 98 LS1 and had the holes redrilled for the new convertor.
Old Nov 29, 2002 | 10:08 PM
Terry Burger's Avatar
I didn't know you could bolt up a 700r4 tailshaft. Is that true? Isn't the output shaft of the TH350 shorter?
Old Nov 29, 2002 | 11:14 PM
I don't know about that one.Just about the Flexplate.
Old Nov 30, 2002 | 04:47 AM
V6 Bird's Avatar
I have a buddy with a 3rd gen that took the TH350 and bolted his 700r4 tailshaft on it. Uses it to hook up his stock TA. Works fine.
Old Nov 30, 2002 | 09:15 AM
Reckless's Avatar
Super Moderator
Bought a stock LS1 flexplate and drilled extra 3 holes for the 6-bolt hub on the Yank converter.
Old Nov 30, 2002 | 10:38 AM
jswhite's Avatar
The TH-350 has different tailshaft lengths. 6 in. 9 in. and 12in. With the 9 in tailshaft it is the same length as a 700-R4.
Old Nov 30, 2002 | 01:57 PM
DR.BOOST's Avatar
I used my stock flex plate from my 2000. Turbo 350/400 converters are available with 2 different bolt circles. The smaller of the 2 will bolt up to the stock flex plate without redrilling any holes.
Old Nov 30, 2002 | 05:59 PM
V6 Bird's Avatar
I will be using the 9" tailshaft. I also will have a 8" TC. 3800 on the brake and a little bit more on the gas. I guess ill have to elongate my holes on the flexplate then. They almost line up but the holes need to be brought in a hair. Guess i can do that then.
