Converting non-PWM to PWM?
So, I have a spare 1996 PWM 4L60E. Could I swap parts from that 2wd transmission into the '93 4wd transmission I have to "convert" it to PWM? I'm not sure which parts I'd need, but I have the entire tranny at my disposal to tear parts from. I rebuilt the '93 tranny myself down to every last o-ring, and while taking apart the '96 PWM tranny I didn't see any internal difference between the years.
Can I, and what parts would I have to swap over, to make my '93 tranny be PWM controlled?
I'm thinking swap the valve body, the wiring harness and all solenoids, plus the pump, from the '96 to the '93. What do you think? Remember that I can swap any and/or all parts from the '96 to the '93 if need be, so if you see this thread again please hold nothing back if I am able to swap parts to make the tranny operate as normal.
No do not swap the pump unless you plan to swap the valve body plate and valve body, Unless you worried about the small anomaly that might be but may not even be noticeable from my experience due to the difference in the 3-2 shift valve. I would just swap the harness and the two solenoids mentioned you do not need PWM you do need a solenoid there to fool the PCM in fact we eliminate PWM from all our units and in the case of our units the PWM solenoid always just acts as a dummy for the PCM it does nothing
All I know is that he uses HPTuner software, and is very good at it. Thanks again for your help. So far you are the only person who has given me hope on this project. This morning I was moments away from purchasing a 2004 4L60E from a 5.3L Suburban just to be done with this hassle, but it's looking brighter every time I read your posts.
I only ask because I came across this quote. I was just going to call up TCI and get their Maximizer 300mm converter but now I have doubts on my decision.
Again, thank you for the assistance, and no I don't have the Trans GO shift kit.
