tranny mount?
Old Sep 9, 2003 | 12:10 AM
98sspullin'em's Avatar
Default tranny mount?
i was changing the stall and when i was, i noticed the black rubber peice was slip almost in half and i went to the track and every time the car shifts, i can hear it, sounds like it kinda hits the floor board, and only when it shifts.. could it be that or something else more complecated?
Old Sep 9, 2003 | 07:48 PM
Ragtop 99's Avatar
Default Re: tranny mount?
It may not be absorbing the shock anymore.
Old Sep 9, 2003 | 08:35 PM
NightHawk's Avatar
Mine's doing the same kind of thing...I think it's the mount. I just ordered one from summit, so I guess I'll see...
Old Sep 10, 2003 | 07:30 AM
let me know man
Old Sep 10, 2003 | 08:53 PM
NightHawk's Avatar
I should get it tomorrow, so I'll probably get it on within a few days. I'll let you know what happens.
Old Sep 10, 2003 | 09:50 PM
thanks!!
Old Sep 15, 2003 | 05:18 PM
NightHawk's Avatar
Didn't have time to put the mount on Today Should have it on in a couple of days and I'll let you know what happens.
Old Sep 17, 2003 | 04:54 PM
NightHawk's Avatar
98SSpullin'em , sent you a PM
Old Sep 17, 2003 | 06:03 PM
DrkPhx's Avatar
I had the same problem and ordered the GM 1LE mount and was told it was discontinued and replaced with a new number. When I received the new piece it was taller than the stock piece which offset the pinion angle enough to force me to remove my driveshaft loop and re adjust the pinion angle. The clunking did go away though.
Old Sep 17, 2003 | 07:25 PM
Ryan K's Avatar
Pathological Modifier
It is just the mount, Under the increased load of the upshift it is picking the back of the transmission up and hitting the floor board. You can replace it with the 1LE or just try a new stock part.
Ryan K.
