Transmission Question
Hey Guys,
On my way back from work, I was able to do my usual 1, 2, 3, 4, 6 shifting. After the first light, I decided to go up through 5th gear, which failed to engage. Then I tried 6th and it didn't engage either.
I could shift into the gear with no grinding or anything, but I had no engagement.
Please tell me this is a relatively easy (and low cost) fix!
Thanks!
Adrian
Thanks!
Adrian
I'll check it out soon. Thanks for the suggestion.
I have 82K and some change on it. The clutch HAS been producing a smell lately with little aggression. I figured it was time to shop for a heavy duty clutch...
I do mostly highway miles and am pretty easy on the car...
I'll let you know how it goes soon. Thanks again!
Location: virginia everything is illegal and cops are assholes
call luke at lindsey do the ls7 clutch flywheel and just change your slave cylinder it will all cost you about 800 parts 50$ for beer pizza and getting your friends to help you for 12 hours one day............... also when was the last time you changed your trans fluid. Once your change your trans fluid with your new clutch and get rid of that super bolky old flywheel your car will feel like new and while your changing that it wouldn't hurt to just do the shifter and you can find one on here or somewhere good for 250 i have the uuc and alot of other mods and am very happy with it all
ya all those being worn and old and not working properly with old fluid maybe even low fluid in the trand and clutch res. the trans wont shift well and dont forget tremec t56 are known for being very notchy AND STUBBORN when cold
My monster stage 2 kit..rated at 525hp and tq from gforce was 990.00 i think shipped to my door. I got the c6 kit, that you have to get, and the lighten 18lb fly wheel. took one week to get it all together I have 1250 for clutch arp fly wheel bolts and pressure plate bolts along with creative steel motor mounts and tranny mount. from what I have read its well worth the price. I called the local caddy dealer who I bought the car from and to replace the clutch and labor was a tad over 3g's just fyi.
the lowest quote I received was a flat 500 for 8hrs on the book. I have a buddy that works for a shop and they let him do stuff on the side so Im just going to give him some money and beer and get it done.
I'll be shopping around for clutches here soon... I'll have to go back and bitch at the dude who serviced my trans a month ago. I took a look at my slave cylinder and it's empty.
I actually have a brand new replacement clutch that came with the car when I bought it. I need to upgrade, but if someone would like it, I'll sell it cheap...
So you guys feel pretty good it's not a syncro or other internals? Just clutch and fluid?
Adrian
PS. Thanks a TON for all the feedback. I can always count on you guys...
Adrian
As clutch material burns off, the clutch fluid in the slave reservoir will go down. This is because the fluid is taking up the space that the clutch material used to be in (it takes more fluid in the slave to get the clutch to where it needs to be.
Adrian
Adrian
Aah...I'm learning a lot.
Thanks for all the help...
I am still wanting to make sure that I understand this right... Having a bad clutch will cause 5-6 (and I just tried reverse and it didn't work) to crap out? I have 1-4 working fine so far...
Sorry for my ignorance. I just want to make sure I understand the situation right before I order parts.
Again, thanks.
Adrian
Again, thanks.
Adrian
I just spoke with a friend that owns a shop in MN. It's sounding like my slave cylinder and clutch may be the culprit. My clutch master cylinder is empty, so I'll top it off tonight and see if I get any results...
Time to research on some of the remote bleeders you guys have posted about...
I'll post if I find any new information.
Thanks a ton for all your suggestions.
Adrian
Adrian
