Last parts of rearend project
Over the last week I've been removing my rear end. I got full Hendrix axles and an 07 diff on the way but what bushings should I get? I realize the axles will kill wheelhop but I feel I should still have poly. Are all 3 usually replaced? What r brands and where can I get em? I had a clunk b4 the rear got worse. And I hate that a caddi makes noise like that and was most certain it was bushings and def from rear. So which n where should I order?
For the one for the ear creative steel makes a good one. Gray polly is the one you want.
So I went to my caddy dealer today to get fluid n he said they were out of the gm stuff n gave me mobile 1 75w90 synthetic "LS" when I asked bout the limited slip addative he said I shouldn't need it cuz the fluid is made for lim slip diffs. So I'm goin with prolly buy it anyway am I correct? Plus how much fluid does an 07 diff hold?
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
yes you do need the additive.
I forgot how much fluid mine took, I pumped in one bottle, then added then limited slip additive, then pump more gear oil till it start to spill back out
( i think about half of the second bottle but cant remeber exactly)
WTF? where'd you get that idea?
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Nearly all synthetics have the friction modifier already in the fluid. Adding more will allow the clutches to slip more, making it an open diff.
Even with the modifier in the gear oil, sometimes you get the chatter and grinding. The V diff seems to like the addition of the modifier on top of the gear oil regardless if it has it in it already.
ok thanks for the input guys i cant wait to get this all back together and
rollout lol i just gotta get the last of my parts and some free time
about those axles tho... does that look wrong to anyone? i guess as long as theyre the same length
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
![Nut swinger](https://ls1tech.com/forums/images/smilies/nutswinger.gif)
