Safe to use "Fix-A-Flat" for a slow leak???
I'm losing about 5-7 lbs of tire pressure every few days. It's a pain in the ***! I do not have the run-flats and will need new tires soon, but I'm not ready to pull the trigger on that just yet. I did plug a hole in the tire in question (6 months ago), and I must have done a crappy job, though it looks right. In any case, Just wondering if the "Fix-A-Flat" stuff will cause any problems that have not occurred to me. I will be getting new tires in a couple of months.
The good news is that all the gas stations in my city (Sunrise, FL) are required by city ordinace to provide FREE air, so I've been able to keep all my quarters! Woo-Hoo!
I used a whole can when I threw a nail from my tire on the dyno. It did not mess up anything. Granted, it was only on my TPMS for about an hour. Not sure what prolonged exposure would do, if anything to the TPMS.
After that I switched to runflats and have not looked back.
I used it on my V when I had managed to get a slow leak. The tires were nearing the point of replacement and I ended up getting new tires about 2 months later. There was no issues with the rim or TPMS sensor.
Tire change techs definitely hate people who bring in fix-a-flat repaired tires. That **** is nasty.
Find the hole and put a worm plug in it. Problem solved. You don't even need to take it off the car. Use soapy water to find the leak.
Check your old repair, take some windex/409/spit and put it over the old repair and see if it leaks.
If it does, see if you can pull it out, and start over, or try pushing it in (you said you want new tires soon, so i wouldn't worry about it floating around in there for a short time)
