Installed FAST 92mm, TPIS 90mm TB & more
so getting ready for the big cam, I jumped the gun last weekend and decided to put parts on. Pictures will be available next week.
Installed: FAST 92mm, TPIS 90mm TB, Lingenfelter 102mm MAF, 42lb SVO green tops, billet fuel rails, 390lph Denso/Kyosan fuel pump and a custom cold air intake tube and air box.
Cam I am going with is a Streetsweeper 236/240
Hopefully STAGEUP will be at my house on Sunday to get this bad boy running. Went into fail safe mode. TOO MUCH AIR FLOW!!
I have one issue that I have to finish up tomorrow and it is regarding the fittings for the fuel rails. Since the fuel is regulated in the tank, what would be the problem with a 3/8 OEM quick connect on the feed line with a Y block feeding into the back of both rails and then the front crossover. Does anyone see any problems doing it this way?? maybe overkill all done in -8an.
strip next weekend.
PHOTOS UPLOADED... not complete but gives you an idea and believe me IAT temps decrease with my setup. I will be coating the inside of the box with some type of heat/sound deadening. some trim pieces still need to be made, but otherwise complete.
This thing screams through 7k with no problem. had to back some timing out due to air loading up in cylinders. ALL THAT MEANS IS THE CAM IS READY TO BE INSERTED, LOL.
![](http://i608.photobucket.com/albums/tt169/verywhitedevil/DSC00138.jpg)
![](http://i608.photobucket.com/albums/tt169/verywhitedevil/DSC00139.jpg)
![](http://i608.photobucket.com/albums/tt169/verywhitedevil/DSC00140.jpg)
![](http://i608.photobucket.com/albums/tt169/verywhitedevil/DSC00141.jpg)
![](http://i608.photobucket.com/albums/tt169/verywhitedevil/DSC00142.jpg)
strip next weekend.
![](http://i608.photobucket.com/albums/tt169/verywhitedevil/DSC00144.jpg)
the pump will be in this weekend or next. wanted to get everything else on and running to narrow down any issues after tuning this weekend. I will PM you the website as they are not a sponsor.
I know. the problem is my friend with the tuner (STAGEUP) works out of town during the week and I am on his time. so I had to wait until this weekend to get the car back and line everything up. Plus, it give me time to finish the custom airbox and intake tube. If it turns out like I planned, could get him to make a few of them.
I'm curious about the intake tube and airbox, can't wait to see the pics. I'm running the FAST 90 and it really wakes up the car up top. I'm actually having stability control issues with it. Even at 70mph it gets shaky and wants to side step because of the stupid stability control. So now I just disable it whenever i get in the car.
@itsslow - I feel you. I had to search and wait to find deals on all my stuff. I ended paying <1000 for all of it and I got 525.00 for the top end I took off. so net <500 for my setup.
