Pacesetter header install review
So...was putting the headers in last night. Whoever quoted 3.7 hrs should get his nuts chopped off. Maybe if everything comes off smooth as butter. Taking off the damn plug wires even turned out to be a bitch. To those that have not removed them be careful they rip very easily. Use some vise grips to grap the rubber part and use the actual engine block to push off of and they will pop out. do not pull! Next Apparently the header on the drivers side does not even fit without taking the control arm off ( It almost does but almost....) Lastly my biggest problem seems to be the simplest thing. Those little extention pieces that fit over the pipes to connect to the corsa leak like a bitch. Everything is fine except that. I went to a mechanic today and they were saying something like you have to use these spring loaded bolts for that connection rather than the regular bolts. He was saying something like the pipe will wedge itself in over time beause of the spring loaded tension. Seems bs to me but idk I cant weld the fkn thing cause there needs to be some flex. Anyone at all on here had that same leak? Granted the cats are gone my car should still not sound almost like straight pipes lol. Oh and If anyone has q's about the install for that specific header let me know. Most noticeble thing is the damn weight difference WOW. The old manifold weighs at least twice as much must have lost a good 50lbs on the change.
hahahaha i ended up pulling my motor for a heads cam swap motor mounts etc so pulling the engine made since in my case... but i too broke every wire a few ceramic pieces on the plugs and i mean i BROKE ALL 8 wires boots wires and all... hopefully when i put it all back together it goes smooth... pulling the factory manifolds sucked too... especially when 2 exhaust bolts broke in the stock 243s... hope i have every thing i need
I did my motor mounts and headers in 5 hours. There a pita to do but not that bad.
Word of advice climb under your car and zip tie the starter wire just to be safe. The one that's clipped the the left motor mount. Also check the Clarence
By your brake line on the right.
i deff had the same problem with the plug wires.. installing my headers alone on jack stands took me at least 8hrs start to finish.. but that includes piecing together the SW 3in cat back kit too.
whaaahahah.. you had to remove the control arm???? I didnt have to do any of that when i was installing my SW headers..
hope your taking the proper heat insulation precautions. naked headers lead to a big FAIL
I actually did not wrap the headers because the more I read the more I hear of all the negatives assosiated with it and its a catalyst for holding moisture leading to rust. Mine are ceramic coat...spent a bit more just with that in mind. However Im still not understanding why they fkn leak at the corsa joints. I dont know what the *** to do. Yeah and I mean there was like a half inch to an inch clearance issue. Thats why I had to remove. Each header is a bit dif so yours may have cleared it just fine. Its just it seems regardless of what exhaust system you have the install would be the same at that junction with the corsa. Not understanding how mine are the only ones that leak there.
i guess you are right but im not spending 1500 on some headers for a 15000 car thats just plain stupid. If I had the new one a dif story. Plus i dont know if im gonna keep it more than another year. thinking going ls7 zo6 next fall been on my mind since I got the v 4 weeks ago.
The Corsa system inlet may not be enough like the factory system inlet in all cases. Be sure the outlet surface of the extension is clean and even all the way around. Check for the same thing on the Corsa inlet "receptacle." If both surfaces are clean and not dinged at all, try coating the inlet with an anti-seize compound or Permatex "Ultra Copper."
