Am I blind, dumb, or stupid.... Setting clock
You press the setup button in the very bottom left corner you can see in this picture.
Then you use the buttons on the right with the on-screen descriptions to set the clock.
When you set the time from GPS, you just have to be sure to click "Ok" from the side buttons. Otherwise it won't stick. That is true if you adjust it manually, except it seems more obvious doing it manually.
To get to the time setting, you can also push the "Menu" button in the lower left.
