cruise control
cruise control
Mine doesn't work and I can't figure out why. Is there a dedicated fuse for it or a module I can check? When I hit the power button it lights up but the cruise itself will not set. 2004 cts v
I haven't ever used it before. I've had the car maybe a month. As far as I know I'm doing it correctly. When you hit the power button on the wheel And try to set it nothing lights up on the dash. Maybe its just me and I'm having a blonde moment. I'll loom again tody.
1 Post
You have to be over 25-30mph to set it. Not sure on what exactly is it... but def. over 30mph for SURE
If you can't set it, you might have to replace that cruise control stalk. Its a $40 part last I checked. You can check the fuses... remember you got 2 boxes under the rear seats too.
yea i forgot about those fuse boxes. im gonna check again and what cruise control stock? my cc button is on the steering wheel. sorry if thats a newb question, im still learning. I was in 6th and cruising at 70 when i was trying to use it.
Yup I figured that out. I reprogrammed the tpms ans I can turn the traction all the way off but can't go into comp mode. Looks like I'm gonna need a reflash on the Nav.
Check out the How To.pdf very helpful.
Picture on this post.
https://ls1tech.com/forums/cadillac-...-engaging.html
