Getting Ready for clutch install
Its time. At 113k miles its time for a new clutch.
I pulled out the exhaust and driveshaft the other day. Tranmission is leaking and the rear diff bushing is shot.
This is going to be about 4 week project.
Here is a parts list I made yesterday. Im going to order the F1 clutch kit $540 shipped.
$26.99 ARP Pro Series Flywheel Bolt Kit 330-2802
$18.99 ARP Pressure Plate Bolts 134-2201
$49.99 Tick Performance Remote Clutch SPEEDbleeder Line for C5 Corvette
$48.14 Transmission Mainshaft PN 89059483
$21.99 TICKshift #95 Isolator Cup (Bronze Upgraded) 95B
$166.10 Total
What other parts should I replace?
Im going to order the creative-steel CTS-V rear bushing $65.00
$166.10 Total
Where is the trans leaking from? You could replace the main shaft seal as well if that was leaking. Aside from that it sounds like you have what you need. I'm getting ready to rebuild my trans in the next few weeks so I have been looking at the same parts. Too bad tick does not respond to my email or they might of had a large parts order.
Order some parts yeaterday. Should get here next week.
Im going to clean up the tranmission and pull the clutch out tonight.
ARP Pressure Plate Bolts 134-2201 $18.99 USD
ARP Pro Series Flywheel Bolt Kit 330-2802 $26.99 USD
GM Output Shaft Seal (Some CTS-V) 89059483 $48.14 USD
Tick Performance Remote Clutch SPEEDbleeder Line for C5 Corvette & Z06, 04-06 GTO & LS1 F-Body TPSBL $49.99 USD
TICKshift #95 Isolator Cup (Bronze Upgraded) 95B $21.99 USD
Tremec #6 Input Shaft Seal 1300-044-015 $14.99 USD
FYI. I pulled the transmission myself and let me tell you, it was a easy. Took about 3 hour.
thanks for this thread - about to do this myself. Question: do you have the PN for the throwout bearing did you used?
hey heavy - what would you consider to be a worthwhile "service"? Meaning, Tick's $1000 T56 service?
Check out the link below. This unit includes a throwout bearing
http://www.tickperformance.com/gm-sl...-corvette-z06/
I wouldn't consider a full on rebuild unless inspection revealed a bunch of stuff that was worn out.
Buy the slave from Orielly's if you can catch it, only $100 but they sell out quick in my experience! For the clutch kit if you haven't already ordered it check out Scoggin Dickey for the LS7
https://sdparts.com/details/scoggin-...center/sdls7ck
Here's the link, looks like they're only $91 now!
http://www.oreillyauto.com/site/c/de...1352&ppt=C0015
