Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Overdriven rears= too much for even the best 6 rib
Old 08-16-2013, 12:13 PM
punishmentcycle's Avatar
Default Overdriven rears= too much for even the best 6 rib
As my luck would have it the Maggie ate up even the gates RACING belt. I've been having a blast since getting the new CS mounts in and well who am I to have fun and not break every damn thing in my path lol. 8 rib here I come!
Attached Thumbnails Overdriven rears= too much for even the best 6 rib-image.jpg
Old 08-16-2013, 12:29 PM
jmargo's Avatar
That looks like a tensioner or alignment problem. How long have you had the Maggie ? Have you had any other belts do that ?
Old 08-16-2013, 12:48 PM
about 4 years...its not a tensioner or misalighnment problem as i use a lazer to square it all any and everytime i change a pulley. the one thing i did have to do in order to get this belt on (as it was shorter than most) was change the tensioner pulley back to the maggie stocker. ill be going back to the v2 acces pulley and a longer belt to get me by till my 8 ribs come in.
my car just eats these 6 rib belts...snapped a couple and stretched all the others a few inches or more in some cases. i even have the maggie HD tensioner and even that doesnt help and in my case stretched the belts the fastest. i BEAT on this car daily so im used to stuff like this..is what it is
Old 08-16-2013, 12:51 PM
one thing i forgot to mention...this was the best belt by far and lasted the longest,didnt slip at all!! but practicing launching and driving as hard as i do id rather have the belt go than a hard part
Old 08-16-2013, 03:08 PM
brack86svo's Avatar
I will pulling the trigger on the swap tomorrow and will be sure to try to post pictures.
I guess seeing this, I better stock up on extra belts. I'm going 3.1 on the jack and will be spinning just under 17,000 rpms.
The thing I want to know, is the new HX installed?
Old 08-16-2013, 03:17 PM
nah man..i was beat after the motor mount swap and last thing on my mind was pulling the bumper..lol ill get it done monday
Old 08-16-2013, 03:18 PM
my temps actually arent to bad in moving air..on the dyno i was up to 157..in cool air im seeing a max of 145 going thru a few gears wot.
Old 08-16-2013, 04:42 PM
1BADCTS's Avatar
Sounds like you need a 10% OD innovators West 8 rib... Just sayin!!!
Old 08-16-2013, 05:04 PM
brack86svo's Avatar
Jesus! He's already pushing that blower hard. The only reason for overdriven crank, is if you don't have room to pulley down on the jack. He's running a 3.0 on the jack, so he has room to go down with an 8 rib if he really wants to.
Old 08-16-2013, 05:07 PM
brack86svo's Avatar
Yeah, I dread anytime I need to pull the bumper. I'll still be waiting for your results though.
I can't wait to get these rears done. Hopefully I can figure out the tuning. I'll be reading anything and everything on HP Tuners for the rest of the night.
Old 08-16-2013, 05:17 PM
1BADCTS's Avatar
I feel like if you're swapping the crank pulley and the blower pulleys anyways you may as well overdrive it and pulley up appropriately on the blower. And besides... I'm selling a basically new OD 8 rib in the classifieds for a good price and would like to see it go to a good home!
Old 08-16-2013, 05:23 PM
brack86svo's Avatar
Full 8 rib setup, or just the crank?
Old 08-16-2013, 06:16 PM
1BADCTS's Avatar
Just the crank
Old 08-16-2013, 09:25 PM
I would onebadcts but I already have one.. Been on there for two years now. I can't spin this thing any faster.. I gain torq but the hp starts to fall off around 5900
Old 08-17-2013, 07:39 AM
slvrvee's Avatar
I had the same problem as you
so I got the upgraded tensioner from Magnuson, but you dont need that since you already have an upgraded tensioner. You could replace your upgraded tensioner and get the 1/2" longer Gates Racing blue belt K061020RB. ( I assumed that you were using the K061015RB)
http://www.gatespowerpro.com/Comerge...tProductDetail
http://www.ebay.com/itm/GATES-K061020RB-Serpentine-Belt-Fan-Belt-/350785719260?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item51ac754bdc
Old 08-17-2013, 10:16 AM
brack86svo's Avatar
I broke the jackshaft on the press. I was using a Pneumatic press and let the pedal get away from me and it snapped. I'm scared to know how much that things going to cost but, I guess I'll find out Monday.
Old 08-17-2013, 10:35 AM
1BADCTS's Avatar
Argh... that sucks. Sorry to hear about that!
Old 08-17-2013, 11:55 AM
Aww man that blows dude!! Make a tool like I was explaining to you. You won't break the new one
Old 08-17-2013, 01:31 PM
brack86svo's Avatar
That's what I plan to do. I already found the bolt that fits in the shaft, so I'll make something up this week. I plan to throw the shaft in the freezer, and heat the pulley. I've decided just to go 1:1. I put the broken shaft back on the blower just to get the car out of the shop, and found that I couldn't get the rear belt on. So I'll order another 3.2 pulley for the rear. With the 3.1 front, I'll be spinning 15,200 rpm, with the stock 2.8, I'll be at 16,800. Stock rears with 2.8 front is 13,969.
Old 08-18-2013, 08:05 AM
raven154's Avatar
I want to say the new shaft is around 300 bones give or take a few. I had to buy one a few years ago.
Quick Reply: Overdriven rears= too much for even the best 6 rib
