Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
What did you do to your V today?
Old 10-02-2017, 02:43 PM
  #1821
rjoffe's Avatar
Originally Posted by vroom_vroom
I know there are several that run 275s on the oem 8.5 and while all the numbers say no it can and is commonly done at the expense of tread life
vroom_vroom,
Take a look at the manufacturer's site to see the actual tire dimensions, there is quite the range between manufacturers, and even within types, some may fit, others not so much. I had a set of R888 in 265 which just cleared stock rear.
Old 10-02-2017, 03:12 PM
  #1822
barrok69's Avatar
Well my wheel saga is coming to a close thank god. Got my last bent wheel off the car thanks to my last one being straight (the spare) My front driver was tweaked at the hub......
So close out my wheels I need to ask a stupid tire question. I know there are several that run 275s on the oem 8.5 and while all the numbers say no it can and is commonly done at the expense of tread life. Well tires last 2 years max with me so I really don't care too much. If I go up to a 275 sport comp will it really make much of a difference in traction?
275's will fit the stock 8.5" wheel sure. The sidewalls will bulge and make the rear end feel wobbly though. You won't be utilizing the full tread of the 275, so I would say its not worth it in that respect, and the fact that the car will not handle as good anymore is another reason to avoid it. A 255 would be the better alternative for a stock 8.5" wheel.
If I recall correctly the R888's run larger than their advertised sizes so that would just compound the "problems" of running a 275 on the stock 8.5" wheel. One of these days somebody will hold these tire manufacturers to their labels so that there can be apples to apples comparisons between brands. Don't hold you breathe though.
Old 10-02-2017, 03:30 PM
  #1823
rjoffe's Avatar
Requires us to do extra research just to make sure it will fit !
Old 10-02-2017, 04:54 PM
  #1824
Doble's Avatar
R888's bulge on 9in rims.
Old 10-03-2017, 02:22 AM
  #1825
Byron's Avatar
(+_+) one day delay on pick up.
They are installing the stainless steel braided brake lines.
I hate working second shift sometimes. Tomorrow morning I'm bringing that sexy chica home.
New motor mounts, acell ceramic wires, ported and painted fast 92 intake with adapter kit, ACT twin disc, tilton 6000 slave, agency power brake lines, new valley cover seal, new rear engine cover seal, new rear main seal, driveline alignment.
Bunch of stuff done, it's going to be worth the wait.
-Byron
Old 10-03-2017, 06:04 AM
  #1826
Mike ctsV's Avatar
Lookin good james
Old 10-04-2017, 08:24 AM
  #1827
rjoffe's Avatar
In an effort to keep brake dust down, I've replaced pads with Hawk ceramics, and cleaned the wheels. Washed, clayed(nano), then coated passenger side with Meguiar's M21 Sealant , and drivers side with Armor All brake dust repellant. We will see which one does better on the dust.
Old 10-04-2017, 09:26 AM
  #1828
kra86's Avatar
Nice stuff, @Byron
Old 10-06-2017, 04:22 AM
  #1829
Byron's Avatar
How it sounds with the new intake and everything else. Click on the picture to take you to my image and video host site to load the video or you will loose some sound quality. Easier to post stuff that way also.
Long tubes, 400 cell cats, H pipe, stock mufflers 3.5" tips.
Its a little louder than pre intake and clutch, you can hear how much faster it revs with the much lighter rotating assembly.
Throw out bearing is coming alive with the existing fluid, I have not yet swapped it.
I'm going to be running a lower viscosity ATE brake fluid, dot 4 class 6 in an effort to tame the tilton throw out bearing a bit.
Tilton literature says fluids with less than 550 f temps should be used as higher temps have additives that swell the seal and can cause slow release.
Redline rl100 produced a fairly stiff pedal effort in the last setup as well, but it lasted longer with the failed slave cylinder than anything else.
Motul is out as its got the same additives, though it is a less viscous fluid. The ATE 200 Dot 4 plus, class 6 seems like it would have the viscosity of motul, which produced a light pedal effort on my ls7 setup, but without the additional additives to swell the seal.
Its a high initial push, but smooth as silk afterwards. Like a good revolver double action is how I would describe it. It is the high initial push I am trying to reduce.
-Byron
Old 10-06-2017, 05:20 AM
  #1830
gravard's Avatar
Really good stuff i hope you guys dont slow down !
Old 10-06-2017, 08:38 AM
  #1831
Tuckin15s's Avatar
I bought a lsa blower for my car.
Old 10-06-2017, 11:29 AM
  #1832
kra86's Avatar
^Kick-***.
Old 10-06-2017, 03:11 PM
  #1833
MarkFJ40's Avatar
uh. Lets see. Last couple of weeks.
Two stage cut and polish followed by a layer of wax.
Replaced the seeping rad. Replaced the steering wheel position sensor.
Rad was damaged and leaking from Rockauto's lack of packaging for a AC Delco rad. SWPS wasnt the problem with Service Stability message.
Ordered a cloned tech 2 to find out it was the ECBM spitting codes.
Got another rad locally and shipped Rockauto back theirs. Checked the wires and connections on the ECBM to find it worked when I plugged it back in. Message is gone. yay. A cheap fix. Sort of...
Got an exhaust leak on the driver side. Do the stock manifolds have a common spot they crack? Couldn't see anything obvious from the top.
Old 10-07-2017, 09:41 PM
  #1834
BudRacing's Avatar
Are all of the exhaust manifold bolts present? It's possible one of the bolt heads popped off. The rears would be most likely to allow an exhaust leak. LS motors are notorious for their exhaust manifold bolts.
Old 10-08-2017, 03:33 PM
  #1835
MarkFJ40's Avatar
No broken bolts. I already went through that on the passenger side.
Old 10-08-2017, 07:42 PM
  #1836
AAIIIC's Avatar
- Completed flushing nasty fluid out of the clutch slave. The fluid that came out of the PMC was pretty contaminated (wear particles from the dying MC, I think), so I wanted to flush the slave before I install a new clutch MC.
I used my Motive bleeder to back-flush the slave initially, in through the extended bleeder line and out through the supply line (which has no MC hooked up to it yet). Happened to have a 4AN-to-1/8" NPT adapter (not sure why ), so I just needed to get an NPT-to-hose nipple adapter so I could hook up the Motive. The nasty fluid above is a result of the back-flush.
Then I flushed the other way a bit, then dumped out the bottle, and flushed a bit more so I could see that the fluid was no longer coming out looking like that. Success!
- Moved on to installing the new (OEM) clutch MC, but had no luck there. Despite what the FSM may tell you to do, as far as I can tell it is physically impossible to twist the MC to the proper position so that the lugs on the MC will engage the mounting bracket; the brake booster gets in the way. This did not come as a surprise - I do recall that the booster was in the way of removing the stock MC, and I had to make a stubby 19mm wrench to be able to take off the outlet hose so that the MC would rotate far enough to disengage. Despite that, I was hoping by some bit of magic I would find that I was able to install the MC without having to go through that process in reverse. Alas, that magic has not happened...
I took a look in the FSM to see how hard it is to remove the brake booster, just so I could shift the thing aside a bit to make room for installing the clutch MC. Well, whaddyaknow, one of the steps in removing the brake booster is to remove the clutch MC! Oh, and it specifically says that you don't need to disconnect any hoses, you just have to remove the MC and move it aside. The folks who wrote the FSM must not have ever actually worked on the car, because I have come across **** like this on multiple occasions.
Old 10-09-2017, 10:35 AM
  #1837
ls1247's Avatar
I put a booster on one of my Vs not long ago and I didn't take the clutch master off. There is a "special tool" they call for and maybe you need to take the clutch master off for clearance to this special tool but o didn't need it.
agajn, I always go to junkyard and rip one open just to see how it all works.
Old 10-09-2017, 08:37 PM
  #1838
AAIIIC's Avatar
I agree, I can't see any reason that you would need to remove the clutch MC to get the brake booster out. I just thought it was funny / annoying that the FSM tells you to remove the clutch master to get the booster out, when in fact it should be the other way around!
I exchanged emails with Robert, the V tech @ Lindsay, and he confirmed that every time he's done a clutch master he has removed the brake booster. So, that's what I did today.
- Unbolted the brake master cylinder from the booster and moved it aside (without disconnecting the brake lines). There's a retainer clip that holds the 2 brake lines on the driver strut tower; I popped that pin out of the sheet metal, and that gave the lines enough flex/slop to move the brake MC.
- Unbolted the coolant reservoir and moved it out of the way, too. I only had to disconnect the small hose coming from the radiator.
- Disconnected the brake booster pushrod from the brake pedal.
- Removed the brake booster. You have to rotate the booster ~45deg CCW (viewed from the front of the car) to disengage it from the firewall. As ls1247 said, there's a special tool that the FSM says to use - it bolts on in place of the MC, and allows you to use a 1/2" ratchet / breaker bar. Well, I didn't have that tool, and it costs $170, so I'm not going to have that tool. Reading online it seems like some folks were able to rotate the booster pretty easily, but mine was not cooperative. I ended up using my 3# hammer and a chunk of steel to knock against one of the notches on the perimeter of the booster. Even with that it took a little while to get the thing to move. Once it was free from the firewall I shifted it towards the center of the car and used a bungee cord to hold it out of the way.
- Installed the OEM clutch master cylinder. Getting the lugs on the MC to line up with the bracket inside the car took some work, had to go back and forth between trying to line it up, then get back under the dash and eyeball how it's lining up, adjust again, repeat. Once I got it lined up it was a tight fit, so I went with the mallet and a piece of wood on the outlet and lightly tapped on that to help get it started, then was able to rotate it the rest of the way by hand.
- Once the clutch MC was in, I reinstalled the coolant reservoir, brake booster, and brake MC, and hooked up the brake and clutch pushrods.
Tomorrow I should have time after work to connect the line to the clutch slave and bleed the system.
Old 10-09-2017, 11:23 PM
  #1839
vroom_vroom's Avatar
Yea I have replaced my booster and didn't have to remove the clutch mc or the coolant tank. It's surprisingly easy to pull
Old 10-12-2017, 06:08 AM
  #1840
AAIIIC's Avatar
- Tuesday I reinstalled the factory dry-break disconnect (with 4AN adapter fitting) onto the clutch slave supply line, and hooked the new clutch master up.
- Flushed/bled the clutch using the old-fashioned manual method, and using a Motive power bleeder. Pedal feels pretty good, but I haven't actually driven the car yet, so we'll see...
- Installed some new super-custom spacers to shift the position of the #7 coil pack so that the plug wire is a bit farther from the header. I had previously used some round steel spacers that I had in my random hardware bin, but they didn't increase the clearance as much as I wanted. The new spacers lift the coil up away from the valve cover, and then move the coil towards the center of the engine ~1".
How did I "fabricate" these sweet spacers/brackets, you ask? Well, earlier this year I demolished an old love seat and broke it down into small enough pieces that I could fit it into my garbage can (because I refused to pay the garbage company $150 to come pick the thing up ). Some of the frame was wood, and some was steel; some of the steel went to the scrap yard for probably a dollar , and a few pieces I kept because they looked like they might come in handy someday. Sure enough, I was able to cut the ends off one of the brackets I had kept, did a little work with the grinder, slapped some paint on there, and voila! The wiring harness to the coil pack has enough slack that it is able to connect without being stretched, and the new position moves the plug wire well clear of the header. (The picture above is a bit of an optical illusion - it shows that the plug wire has good clearance, but makes it look like the A/C pressure sensor is right on top of the header primary, which is not actually the case.)
- Last night I hooked up the battery and reinstalled all of the interference that was out for the clutch MC install. Once it was all back together I pop-started the car rolling backwards out of the driveway, then pulled back in. Clutch works! Starter still doesn't, so that's the next project.
- Finally swapped back to street brakes. Since the car was towed back from the track, dead, it's just been parked in the driveway while I waited to get the clutch MC addressed. I hadn't bothered to swap the brakes back over, so I knocked that out (in the rain) last night.
Quick Reply: What did you do to your V today?
