Ls3 into a 06 V
Ls3 into a 06 V
I just recently bough and 06 v that currently spun a bearing. I am looking to do a ls3 motor to it. I have one lined up but just wanted to make sure everything is pretty much plug and play. I have done some researching and could not find a good write up. if anyone could help me out that would be great. Thanks
LS2 CTS-Vs are super easy to swap to LS3. The ECU can read the 58x crank reluctor, which is one of the biggies. Knock sensors are in the same spot, as are pretty much all other sensors. The LS2 map sensor has a smaller nub that goes in the intake manifold, so you have to put a piece of hose on it. That's about it.
I wanna build a 9 second V1 that I can daily drive (including winters here in Ontario)... someone spoon feed me all the relavant info (I'll even add a 'please' because I'm Canadian)...
I joke...
I joke...
