Low RPM bucking in a mostly stock CTS-V?
My friend just bought an '05 CTS-V, and it's bucking at low RPMs. All it has is a K&N CAI, and Borla exhaust, 53k miles.
It's been bucking under load at <2K RPMs. It's fine at high RPMs / WOT.
Any ideas what could cause it? Maybe the K&N is screwing with the MAF readings? CEL also came on last night, will scan today.
Thanks
Matt
Thanks
Matt
you pull DTCs via the OBDII port. Autozone will do it for free.
If you suspect the K&N, I'd recommend buying some CRC Mass Airflow Sensor cleaner and clean that dude. Often, people over oil the filter (even seen them new that way). The excess oil blows through under high flow rates and deposits on the MAS wires. This alters the readings the PCM gets. It won't hurt to clean, that's for sure.
Took the car to NC and back and the problem was very intermittent. Resetting the ECU (pulling fuse) made the problem go away sometimes, other times no luck. A WOT blast here and there seemed to help and driving it part throttle for extended periods seemed to make it worse.
Will try the MAF from my Z06 and take it from there.
