need a timing table msd 6010 users!
In-Zane Moderator
Do a initial idle timing of 18*, then ramp it up from 1000 to 33* by 2000, then from 4000 go 33, then 31* at 5000 and back up to 33* at 6000.
That is a goof base timing for you, from there, once on the dyno or track, start ramping the timing up, mine is at 20* idle, then 35* by 2000 and ramps down to 33* and back up the way i told you to do yours.
