Which carb for me????
I have a stock bottom end ls1 with a big cam 242@50 & 636@600 with cnc ported 5.3 heads that flow like 317@600 with a victor jr & a mighty demon 850 race carb & its rich maybe a need to jet it down or do you believe it needs a 750 instead?
Chang carb
First off, you need to R&R the engine into a chevy body! No, just kidding. Sounds like you are over carbed, I would definately try a 750. You will probably like that setup better. Good luck!!!
Manifold vacuum is a good indication of what the engine is asking for as far as carb. If the engine is pulling over 1.5 inches at WO throttle its a good possibility it might like more depending on how you are using the engine. My guess is that it wont see that level of vacuum on an 850 if u arent turning more than 7000 RPM. The 750 might see that much but it might give you better drivability in the lower R's.
850 all the way. Just take a little time and tune it in correctly. I have a 950hp on a LS1 on the street and it runs better and is more responsive than the 750 demon I had on it.
With the car being that light, high stall, and 7000 RPM I would stay with the 850 and work on tuning it. The 750 would have better acceleratoin but fall off a little on top end. Once again I feel that with all of your information you provided you will be ok with the 850.
Interesting dyno test where they try all the popular holley sizes
http://www.superchevy.com/technical/...ght/index.html
Get the big carb tuned right, and you will be rewarded with more power than the small carb, with no trade offs.
Remember, these Ls motors breathe pretty heavy for little motors, they like lots of flow. If you Choke it with a restrictive induction setup, you can kiss the power potential goodbye. Dont close your mind and treat it like an old small block, or you'll be doomed to make the same power as that old smallblock.
Old School Heavy
Have you actually done back to back testing on this 3pedals?
