MSD 6010 What ignition timing chip should i be running?
i've been racing the car for almost 2 years now and i've been running the number 4 ignition timing chip and the car has been running good. i was wondering if i should start changing chips to try and get little better E/T out of the car. should i try and set my own timing? should i try different chips?
What chips r u guys using?
Thanks
Anthony
Thanks
Anthony
Man, i went from the most aggressive chip, to my own tune, all i can say is it was night and day, a whole different car.
Should we say more?
We have a thread in here on recommended curves, or what we are each running anyway.
Should we say more?
If I remember correctly, the box will default to the curve that is produced by the #3 pill if you don't set a curve yourself or if you don't insert a timing pill. If you didn't get any paper work with the box you can go to MSD's web site and download the instructions which also include the specs for all the timing pills.
From: Your girl's back door giving her the long stroke while you're at work
mines only been on pill 1 as a base dyno and break in period
i know i made a curve and loaded it and seems a lot perkier and peppy havent been back to dyno to full on tune it yet thats coming late spring
The short answer is yes. If you have the MAP hooked up it will produce the vacuum advance curve that is specific to that # pill. Although most of the pills use a similar curve, there are slight differences. Again... the instructions show the advance curves and the individual vacuum curves for each number pill. The trick for most people is trying to convert MSD's PSIA numbers to the more familiar inches of vacuum. If you do a search, there is a coversion chart on here somewhere.
