Timing on a LQ4.
https://ls1tech.com/forums/carburete...ed-timing.html
What about the MAP?? I have no idea what to do with it.... I put a the #6 chip in and just used the map from it....
And there is a Four Degrees difference between what I set it and what it is when the car is running.... Example set a 32 degrees and with the computer hooked up and car running says it's at 36 degrees.... Any reason for that??
Thanks for the help guys.....
It seems fairly typical that guys will back the timing off by 2 degrees at peak torque...usually from 4000-4800 or so depending on your powerband obviously.
ls6 heads .580 lift cam
dynatech long tube headers
th350 trans
373 gears
msd ignition box
I ran the curve 6 tune from msd tweeked it just a little (turn the rev limiter to 7k, set the timing on the top end to 38°) an my fastest pass was a 7.47 at 93mph with a 1.7 60ft but consistently ran 7.6s all night but I’m on drag radials...
its my my first ls motor used to small blocks so pretty much just curious how far y’all have gone with the timing and if I can go any further..
i am tweeking a new set up adding a little more timing at idle to see if it gets me out the hole faster
