fuel pick up problem?
Use the phone at the school to call the wife and hoof it back to the car with the boy. Long story not so short I have her bring the 5 gallon gas can from home and I put the 3 or so gallons in that was in the gas can. Now after I put the gas from the can in I can hear the cheapo AC Delco in line electric fuel pump change tone, like its now picking up fuel. So I figure I ran out of go juice.
Drive to the nearest gas station to fill her up because I thought my fuel gauge was not working. I had just replaced the sending unit last fall because the gauge wasn't working. So I thought something was up with the new aftermarket sending unit. So I get to the gas station and less than a gallon later and I'm spilling $4.25 dollars worth of 93 octane all over the ground.
Limp her home and yesterday I drop the tank. I drained a guestimated 12 gallons out of the very full tank. Pull the sending unit, blow everything out with air and all looks well. No crap, schmeg or anything else unusual that is jumping out at me.
Little back ground. Fresh iron block 370 with a new to me, used Quick Fuel 850 that I just picked up. I have the fuel comming out of the tank to a filter, in line variety that you would use on any stock carb variety fuel system, nothing fancy, don't know how many microns it picks up. From there it goes to chepo AC Delco fuel pump up to Holley regulator, up to carb. Now I have one of those screw in fuel pressure gauges at the fuel log, up at the carb. Most times it only shows 2-3psi. I never had a fuel starvation problem so I thought the gauge was off. I had the regulator opened up to let as much pressure through as possible and still only 2-3 psi. Everything in the fuel system was new from when I did the swap in 2008. Probably only put 15-1800 miles on the car since the swap.
Any thoughts on what the problem was? I thought it was a pick up problem but I think I ruled that out once I pulled the sending unit.
Tomorrow I have a new Summit 140 gph, 18 psi (at least I think thats what it said) fuel pump with Summit inline filter (40 microns incase you were wondering). The sending unit I bought last year has a 5/16 return line that I intend to plumb in. I hope this will solve any fuel problems I had. I'm just looking for some thoughts on what anyone may have thought the original problem was.
Thanks for looking!
Greg
Also be sure all the connections from the pump intake to the tank are sealing tight. A small air leak on the suction side will cause all sorts of issues. I'm sure you have already checked the plumbing for restrictive connectors or collapsed hoses.
Chances are your fuel pump was just not working well. You should have plenty of fuel with that summit pump.
Thanks
Thanks !!
Thanks !!
Thanks
