Low profile air cleaner setup?
502cid LS so need around 1000-1200cfm. As you can see, TIGHT room (that's a plastic mockup carb, spacers are to represent the gmpp lsx tall deck intake manifold ... I only had access to an ls1 intake manifold for my fitment)
![Name: carb3-2.jpg
Size: 40.9 KB](https://ls1tech.com/forums/attachments/carbureted-lsx-forum/674392d1501791986-low-profile-air-cleaner-setup-carb3-2.jpg)
![Name: carb1-1.jpg
Size: 38.1 KB](https://ls1tech.com/forums/attachments/carbureted-lsx-forum/674393d1501791986-low-profile-air-cleaner-setup-carb1-1.jpg)
Here is is with a 3 1/2'' spectre plenum hat
![Name: carb6.jpg
Size: 32.9 KB](https://ls1tech.com/forums/attachments/carbureted-lsx-forum/674394d1501791986-low-profile-air-cleaner-setup-carb6.jpg)
So far the most appropriate thing I can think of is a spectre low profile sheetmetal plenum filter, a-la
![](http://www.bowtiepartsstore.com/ShowProductImage.aspx?FileName=87b1de66-02f1-4e67-b77d-7a75c82b4de2.jpg&ImgType=ProductImage&ImgDim=279&StoreID=1124&StoreName=bowtiepartsstore)
![](https://i10.photobucket.com/albums/a123/Dennis-325i/BhuEZQmkKGrHqMH-EUEsL4fZ9ZBLKd9MByU.jpg)
but obviously this type of filtering is not the most efficient/best setup.
However, w/ my constraints I'm thinking it may be my only option?
![Name: carb3-2.jpg
![Name: carb1-1.jpg
![Name: carb6.jpg
I really don't see any other way around it. It doesn't get much more low profile than what you've shown, and that is already hindering airflow.
There are a couple of options though. Shorter intake manifold i.e. Vic Jr. or shaving some off of your intake manifold. Also, I know this will get shot down because I'm sure you want the car to be carbureted, but going the fuel injection route would also eliminate the problem. Sorry I couldn't be of more assistance.
About the only thing I can think of doing is using that low profile carb plenum, then run flexible ducting
![](http://www.racetechdirect.co.uk/images/products/E2025A.jpg)
to both of my sidescoops so the air filters are blasted by continual cold air. Maybe the cold-air effect will help offset some of the suckyness of the filtration setup, heh?
I also can't move the engine rearwards or downwards anymore than it already is.
Yea, basically what I'm going to do is
- use low profile spectre plenum
- position 2 6'' filters at the rear of the engine/above the transaxle
- build a box with heatfoil that surrounds the filters to reflect radiant heat
- build a carbon fiber air scoop that replace sthe rear window, like this, but more visually appealing and smaller:
![](https://wot.motortrend.com/files/2010/06/29651173.jpeg)
Obviously adding ducting from there to the air filters would be best, but for simplicity I'd just leave the filters unducted and let air blast it at speed
