E85 anybody use it?
"E85 has an octane rating higher than that of regular gasoline's typical rating of 87, or premium gasoline's 91-93. This allows it to be used in higher-compression engines, which tend to produce more power per unit of displacement than their gasoline counterparts. The Renewable Fuels Foundation states in its Changes in Gasoline IV manual, "There is no requirement to post octane on an E85 dispenser. If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanol’s blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanol’s true octane value should be used to calculate E85’s octane value. This results in an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual-octane engine tests." [6]"
Also e85 is be much less fuel efficient as it takes more to get the correct air/fuel ratios.
You need to be aware also it is very corrosive, special seals are required or materials for your fuels system and due to the increase fuel usage a larger fuel pump.
I thought about going this way but did not also not available most places as mentioned above.
Regards,
Bruce
You can also order it in 55 gallon drums for a lot cheaper than out the pump. Most 55 gallon drum purchases work out to around 2-2.50 a gallon. Since your not street driving it you might be able to do it.
If you have a station 27 miles away, then bring a couple 55 gallon drums with you and when the price is cheap then buy it up. That was what we did. This is my 4th year running the fuel. I buy it straight from the pump. I am also going to run it on my LS1 twin turbo with NO INTERCOOLER! Awesome fuel! 105 octane!
