Timing pills ???
Make your own curve....pills have problems.
EVEN IF the map is NOT hooked up....they will add timing and one has found out and warned.
MOST say the curves are too much ?
Lots of reading at the to of this this page
wild, the msd pills use a 5500 rpm limiter. only way to get rid of that is make your own curve.. and the timing seems high if ya ask me, plus the worry of the map thing adding timing
