LQ4 in a 1971 Nova
Old Apr 1, 2013 | 06:25 PM
  #301
frojoe's Avatar
Those tails look awesome, reminds me of my custom LED tail light bucket setup.
Those front signal LED's.. could they be, dare I say, too bright? And with a clear lense and white LED, any plans to add any amber color in there?
Old Apr 2, 2013 | 10:00 AM
  #302
hookemdevils22's Avatar
thanks guys. Rich, I'll get a hold of Philip. He coming to the cruise this weekend?
Joe, the fronts are serious bright - the white LEDs overpower the ambers. in fact, the second pic actually has the ambers illuminated. I've got a set of higher-intensity amber lights on the way. the lenses also don't lend themselves well to LEDs, so I'm going to attempt to cast my own without the pillows on the forward side.
Tony, HIDplanet.com is a great resource for retrofitting LEDs. here's a link to my thread - there's a guy on there that did a 69 Camaro.
Old Apr 2, 2013 | 03:16 PM
  #303
Found a set of wheels I like at wheelstudios. Plan is to buy the 18x8.5" and 18x9.5" and have the rears widened to 11". That would put BS at 6.13" front and 8.38" rear, which I could fix with my spacers.
Old Apr 2, 2013 | 05:14 PM
  #304
tsnow678's Avatar
Glad you found something you like. I had to go in and pick the lug pattern without using the car filter to find those wheels. Here is something similar if the other do not work out for you.
Old Apr 9, 2013 | 11:30 AM
  #305
Well, those wheels are no longer manufactured. I might still go with the RPMs, but I'll wait until after the mini-tub is done to pull the trigger. I just don't really like the black look, or the lighter silver - I'm pretty set on gunmetal.
We made a 160 mile trek to Wickenburg on Sunday with the ET Streets and pizza cutters as part of a cruise - the longest I've taken it at one time since the LS swap. Sad part - I ran out of gas a couple miles from home, despite the gauge reading just under 1/4 tank. I filled it with 10.5 gallons, though the stock tank is 15 I believe. Sooooo... that's odd. Also, my fuel pump relay overheated a couple times, leaving us temporarily stranded on the side of the highway until I replaced it. The wiring is 10 gauge back to the pump, so I'm pretty sure that's not the problem. Maybe it's the close proximity to the headers. Swapping relays seemed to do it.
I also began the mini-tub last night. I got a little overzealous with the angle grinder when sanding off the coating, and removed a little extra material (see if you can figure out where). I'm following this write-up from TCI, though I'm deviating slightly since I'm not replacing my inner wheel housings (it would be over $200, and at that point you may as well buy the DSE tubs). Since I'm adding 2" strips, rather than DSE tubs like Joe, I'll provide some pics.
Spot welds drilled out. I used a 5/16" bit, though a 3/8" would've been better, as I had to break bits of weld with my chisel after drilling.
Driver's side - you can see that I cut the tub with my chisel trying to break the weld I didn't drill out. It'll be flattened and filled.
Passenger side. Much nicer.
Brackets removed.
And a little extra material removed (whoops). That was with a sanding disc - imagine what'll happen when I get a cutting device in my hands.
Old Apr 9, 2013 | 01:30 PM
  #306
bczee's Avatar
Looking forward to seeing more of the work on the tubs !.. keep up the good work.. nothing like putting a little blood, sweat and tears into the project ! LOL..
BC
Old Apr 10, 2013 | 12:44 AM
  #307
Drivers side is done. Sawzall FTMFW. I planned to leave a lip surrounding the tub, but wasn't able to for reasons shown below. And I still have all 20 digits!
From the cabin. I need to get rid of those drums...
From the trunk
Wheel side looking forward
Here's the forward part of the tub before I cut it. I'm pretty sure I made the cut lines when I was in high school. I cut along that, and plan to reattach to the rear support when I reinstall the tub.
Tub removed. Black is forward (from when I laid down rust oleum).
Forward portion of the tub. The metal below this point (in the car) is mighty thick. I scrapped a saws all blade before I figured it out.
Here's why I had to cut so close to the tub, instead of cutting a lip around it. Notice the upper shock mount sandwiched between two pieces of sheet metal, which I partially cut through, as well as the Proximity to the frame on the right of the picture. Both will be removed (the frame notched).
Old Apr 10, 2013 | 08:09 PM
  #308
beater6.0's Avatar
nice pics. makes me wanna get the sawzall out and cut mine out
Old Apr 11, 2013 | 03:13 AM
  #309
tsnow678's Avatar
Wow Hookem your not playing around! You and FroJoe got some big ***** to cut up on a running/driving car like that. Hats off to you sir, can't wait to see the final results.
Old Apr 11, 2013 | 11:26 AM
  #310
Mas...
Post-2" secton removal, pre clean-up (sawzall got snagged by the underlying sheet metal). The wheel well cuts are clean though. And I'll be much more careful on the driver's side.
You can see I was able to salvage more of a lip on the passenger-side wheel well.
Now, I ran into a small snafu... my panhard bar mount is attached to the passenger-side frame rail where it begins to kick out (aka part that needs to be removed). Same with both spring mounts, though they're less pronounced and therefore easier to modify. So I'll likely remove the bar and have the fabricator cut and remount it. I'll be cleaning up the area over the next few days. And I'll admit I'm a little terrified right now.
Old Apr 26, 2013 | 10:48 AM
  #311
-TheBandit-'s Avatar
I know that feeling of being terrified. It's unsettling to see the ground through an opening in your trunk, but you'll get the job done - just take your time. It's going to be awesome when you're finished!
How do you like that Taylor battery box? I may be moving my battery to the trunk also. There are so many ways to wire it - what method did you chose? Remote solenoid? Single wire to start & alt or dedicated charging wire? Cutout switch?
Old Apr 26, 2013 | 11:42 AM
  #312
So I got the frame patches welded in, and tacked the passenger-side wheel well. I spent a lot of time cleaning the crap off the areas to be welded and inside the wheel wells themselves (lots of rubber). Also, I was a little over-zealous with the cutters, so I'll have to fill some gaps. Luckily my BFH took care of a lot of the gap issue. I still have some cutting to do on the driver's side, but I should have both done (maybe not the 2" strips though) this weekend.
Clint, I like the battery box. It looks great for the price, though it is a little flimsy. I recommend it though. I used a turn-switch (as opposed to a push-pull) that I bolted to my rear bumper. The only real pain is running the alternator wire alllllll the way to the back to comply with NHRA regs.
This is literally my first legitimate welding project, so don't hammer me to hard for my weld quality. I plan to do spot welds down the wheel wells to minimize burn-thru. Also, my square is 2" wide, thus why it's in the pictures.
Old Apr 26, 2013 | 07:52 PM
  #313
tsnow678's Avatar
Looking good! Are you going to use flat metal to fill the 2" gap or get fancy and roll a step on each side of the strip to have a flush finish on the top side? What size of wire are you using? If you use .023" you shouldn't have much issue with burn through if you keep the welds cool and space the welds correctly. Are you using flux core or MIG? Can't wait to see the finished product, so far so good!
Old Apr 26, 2013 | 08:06 PM
  #314
SlvrSierra4.8's Avatar
Is it just due to cost that you are stretching the stock tubs? You can pick up the Dynacorn deep inner tubs for about $200. Either way going to be well worth the time to minitub, changes the whole attitude of the car for the better
Old Apr 26, 2013 | 08:50 PM
  #315
Tony,
-Flat metal. I saw a company that makes the stepped inserts for 1st and 2nd gen Novas for around $100, but nothing for the 68-79.
-.o23" wire. I had to play around with the voltage and wire feed, but I'm fairly certain I'm getting good enough to preclude burn-thru, for the most part. Filling holes in my floor pan has helped me figure out the settings and touch.
-MIG. Miller 135 I'm borrowing from a buddy. I've got a smaller welder Im picking up from my dad next time I'm up in Washington.
Sierra, it's mainly cost. I saw a write-up on a 1st-gen camaro on TCI's website that used new inner tubs. But there are enough DIYs out there that I decided to try modifying mine. The worst part is definitely removing the undercoating and crap from the tubs, which obviously wouldnt be much of a problem with new inners.
Side note, Arr you keeping VVT with the LY6/T56 you're doing? I'm interested to see if anyone could make that work.
Old Apr 26, 2013 | 08:57 PM
  #316
Also, I've been looking at wheels. A lot have deep offsets, but I've got a set of adapters I can use, which feature a ford bolt pattern. So I'll likely get something with a 5x4.5 like Joe did. Here's two I'm seriously interested in.
TSW Nurburgring (gun metal).
Positive: 10.5" rear wouldn't need to be widened for a 305; Spin forged, so they're just over 20 (18x9") and 21 (18x10.5) lbs, per TSW.
Negative: no lip (here's an idea of what they look like on a vintage car, though it's a mustang.
TSW Tremblant (matte black)
Positive: 2" rear lip; the black does look pretty nice (better than gloss, at least)
Negative: rear is 9.5", so id have to spend another $450+ to have them widened; cast, so they're about 5 lbs heavier per wheel vs. the 'Rings
Old Apr 26, 2013 | 10:07 PM
  #317
That's been done
http://www.google.com/url?sa=t&sourc...h_3hOM4msTW_sA
Old Apr 26, 2013 | 10:40 PM
  #318
Ahh, I hadn't seen that! I'm pretty sure cam was trying to do it, and/or someone in a 3rd-gen firebird. I actually saved that guy's hybrid T56 write-up for when I swap over. What cam did he end up with- TSP?
Old Apr 27, 2013 | 01:57 PM
  #319
Answer: VVT2
Anyway, progress. I can practically drive it now! Just need to put a bead down behind the rear seat divider on each side, then cut and weld in the 2" strips.
Yes it's getting too hot... High of 97 today.
Old Apr 27, 2013 | 06:26 PM
  #320
tsnow678's Avatar
I like the TSW wheels but I am with you on the lip. I put a set of these on my son's Mustang and they look great. Not sure how they will look on a Nova but here they are on a Mustang. One word of caution: the charcoal matte wheels are a pain in the ars to clean between the spokes.
[IMG][/IMG]
[IMG][/IMG]
