Ca engine swap emissions question
There should be no reason you can not use a so called HD engine, The swap will be based on the VIN in the ECM and all supporting SMOG equipement must also be used and installed per OEM Spec. (granted there is a little room depending on how you read the law and how the Referree sees it, but not much) You basically turn your 86 truck in to a new truck and it has to meet the same testing requirement as the donner engine.
You would need to keep the Cat's, EGR, AIR, Fuel tank Pressure Sensor and level, EVAP, Vaper Charcoal Canister, PCV, etc from the donner Truck. If the Referee wanted to get real picky, He will check the casting and part number and ask you for documentation to match. But much of this is the is worse case.
Research this on the Calif DMV site and find and talk to a Smog Referee (talk to a few), as they are never the same in thinking many times.
Thanks for all the info.
If this all goes right i will be swapping my elcamino over too.
Engine Change GuidelinesOverview
Engine changes continue to present problems and challenges to car owners and technicians. Here are some tips to keep you and your customers on the straight and narrow.
Our recommendation is to rebuild and reinstall the original engine, transmission, and emission control configuration.
When rebuilding an engine, it must be rebuilt to the original equipment specifications. However, if you do decide to change the engine, these guidelines must be observed to ensure that the vehicle will be eligible for smog certification or registration.
Remember, these are guidelines for performing engine changes – not certification procedures. All exhaust emission controlled vehicles with engine changes must be inspected by an official referee station and must have a Bureau of Automotive Repair (BAR) Vehicle Identification Label affixed to the doorpost.
Remember also, state and federal anti–tampering laws generally prohibit any modification to the vehicle's original emission control system configuration as certified by the manufacturer. And, Section 3362.1 of the California Code of Regulations prohibits any engine change that degrades the effectiveness of a vehicle's emission control system.
California Certification
A federal Environmental Protection Agency (EPA) certified (federal or 49–state) engine cannot be used in a vehicle that was originally certified for California.
Certification Standards
Make sure the engine and emission control configuration on exhaust – controlled vehicles are certified to the year of the vehicle or newer, and to the same or a more stringent new vehicle certification standard.
Classification
Don't mix engine and vehicle classifications which will degrade the emissions certification standards. For example, a heavy–duty engine cannot be installed in a light–duty exhaust–controlled chassis even if they have the same displacement. Non–emissions controlled power plants such as industrial or off–road–use–only engines may not be placed in any exhaust–controlled vehicle.
Computer Controls
If a computer–controlled engine is installed in a non–computerized vehicle, the "CHECK ENGINE" light, the Original Equipment Manufacturer (OEM) diagnostic link, and all sensors, switches, and wiring harnesses needed to make the system fully functional must also be installed.
Emission Control Configuration
Mixing and matching emission control system components could cause problems and is generally not allowed. Engine and emission control systems must be in an engine–chassis configuration certified by the California Air Resources Board (ARB) or U.S. Environmental Protection Agency (EPA). The engine must meet or exceed the requirements for the year and class of vehicle in which it is installed.
Emission Warranty
Voiding the vehicle manufacturer's emission warranty is not allowed.
Engine Modifications
No internal or external engine modifications (cams, pistons, intakes, etc.) may be performed unless the parts are ARB–exempted or EPA–certified for use in the installed engine. Use the database on this site to search for aftermarket parts covered by ARB Executive Orders.
Original Equipment
The installed engine and host chassis must retain all of their original emission control equipment. Diesel–to–gasoline conversions must have all gasoline engine and chassis emission control systems installed (such as fillpipe restrictor, catalytic converter and evaporative emission system).
Smog Inspection
These vehicles must pass a complete smog inspection (visual, functional, and tailpipe).
Be sure to check for updates on California's DMV and other gov site for your correct Be sure to check for updates on California's DMV and other gov site for your correct intruptation of the California Law or any other State Law.
http://www.bar.ca.gov/80_BARResource...uidelines.html
IMO.. go 6.0, the extra 80 lbs from the iron block is not going to make any difference being in a truck, but the fuel mileage and power of the 6.0l will !
I would say, any of the truck pans would work... LQ, LM or LH... they all have short lower slump's.. I don't think it is anything that you would have to worry about.. unless you really move the engine forward and lower. maybe someone with a spare Truck pan could take a picture of the SBC pan to compare to put you at ease.
but I need to finish hooking up the ca smog equipment. I think I have all the
stuff on it , except the Purge to the EVAP canister. Can't I use the old 85 canister that has a hard line that already runs back to the tank?
