1998 Sonoma LS1 6-Speed Swap
Got a few questions regarding swap that I've about got wrapped up. First of all the throttle body coolant line, I think thats what it would be called, for the time being I have it capped off. What do I need to do with this to have it working properly? My other question is about the fuel pump. The truck was originally a gustless 4 banger, and I have been told that the pump will work with the LS1 motor, Is this true? If anyone can help I would appreciate. Thanks
The 4 cylinder fuel pump will not work will the LS1. You can easily upgrade to the flexfuel pump or splice a Camaro pump in. Check out the LSX stickies on S10forum.com.
take it to Intune in Cleveland, TN. theyre really good with LSX stuff. they went through my pcm and deleted my rear o2s, the AIR system, and the Skip Shift for $50
