How much of the wiring is necessary?
Here's the under dash and engine bay harness, 22lbs of crap.
plus the actual engine harness
Any insight would be sincerely appreciated,
TJ
happen to have the pin-out for the connector that comes off the engine harness and goes through the firewall on the driver side by the brake booster? Guy I bought this from couldn't get the grommet out, so he cut the harness and spliced some crap. 2 leads are now too short to reach the connector, so I need to lengthen them and figure out where they go..
thanks again,
TJ
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Along with the wiring diagram provided above, I'll need to fish the OBD2 port out of the under dash harness so that I can tune/interface with things. At what point should a guy try to sell off the stock ECU, BCM, harness(es), and whatnot and just buy the GM LS Controller kit (which includes ECU, MAF, O2s, BCM, and pedal)? Seems to only have the essentials in the harness. Probably sell of all my take-out stuff and be within a couple hundred bucks of the 19166568 controller kit. Thoughts?
Basically look at this link about the OBD2 port. (scroll to the bottom). I prefer diagrams so...
What you need is in bold, unnecessary bagpipes and bullsh!t is gray.
Pin 2 - J1850 Bus+
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
Pin 7 - ISO 9141-2 K Line
Pin 10 - J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line
Pin 16 - Battery Power
Last edited by gofastwclass; Dec 14, 2009 at 01:14 PM. Reason: the usual... short between keyboard and brain... :)
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
I'm sure NOS327 appreciates you clearing that up, I know I do.
Mike
guess I need to start doing some more digging about the appropriate pin-outs for the gen 4 stuff.
As suggested before, at what point should I abandon the pile of stock parts I have and look into a more swap intended "kit"?
Thanks again,
Andy
90% of the 05-06 GTO harness "stand alone" part comes thru the J1 connector to the ECM.
We offer a finished J1 replacement harness that allows you to plug in and get up and running quickly and easily:
If you're sifting thru a factory harness to simplify it, this is basically what you want to end up with.
www.speartech.com
www.speartech.com
Yeah but he had also mentioned that he was wanting to use the DBW feature for cruise as well..
Wouldnt he also need the BCM and the wiring to the ECM for that function?
