Questions for the Fox guy's
Old Dec 17, 2009 | 12:03 PM
jleews6's Avatar
Default Questions for the Fox guy's
I did a search but the only thing I found was info on the aftermarket stuff. My questions are
1 has anyone used the stock K member?
Has anyone used the stock 6.0L truck manifolds?
Thanks.
Old Dec 18, 2009 | 08:17 AM
dmracing's Avatar
They use the stock sn-95 k member for the 4.6. I dont believe the manifolds will work on the drivers side.
Old Dec 18, 2009 | 04:14 PM
chevynutss's Avatar
I am doing the same thing. My fox body already came with a 4.6 k member from a 97 Cobra. A freind of mine lastnight gave me give stock 4.6 motor mounts, and another friend is giving me his 351 swap headers. (It helps when all my friends run mustangs) I have seen people cut the flanges off those and weld ls1 style flanges onto them. I'm going to start mock up as soon as christmas gets over with and I will post pictures as I go.
Old Dec 18, 2009 | 04:54 PM
Isolde's Avatar
The '00 Z28 SS passenger side exhaust manifold is a good fit, but the driver's side won't clear the stock steering shaft. I tried those manifolds first. I've seen pics on here of the truck manifolds turned around for a front turbo, they seem to fit that way. I was using the stock '89 2.3L / A4LD k-member that came in my '89 Mustang LX. The oilpan was 3" lower than that, and then the snow arrived, so that's as far as I got this year. I'll try other oil pans come spring.
Old Dec 19, 2009 | 03:15 PM
chevynutss's Avatar
Which oil pan did you use? I have a truck pan and a fbody oil pan. I dont know which one will work best as of now.
Old Dec 19, 2009 | 11:41 PM
boosted5038's Avatar
Thanks.
6.0 truck manifolds here. once you cut off the factory sway bar mounts the manifolds fit like they were made for the car. just realized you were'nt asking about a turbo setup. my manifolds are flipped around.
Old Dec 20, 2009 | 07:31 PM
ucf_stang's Avatar
the F-body pan will work the best for clearance.
Old Dec 21, 2009 | 10:52 AM
72Elkytpi's Avatar
I used BBK long tube 351 headers and had a muffler shop weld on the ls1 flanges. Its a cheap way for now until I get it all running. Steering shaft is rubbing still a bit so I may have to move things a little or dimple one tube.
Old Dec 23, 2009 | 03:02 PM
Isolde's Avatar
my test fitting was all done using the truck oil pan. I suggest trying something else instead of trying to get the truck pan to work.
Old Dec 24, 2009 | 02:30 PM
getsum27's Avatar
i used the 351 headers with ls1 flanges to...
same problem with steering shaft
also had to do a lil massaging on bottom of firewall to get them to clear but the price difference is worth it
Old Dec 24, 2009 | 02:56 PM
Dickie-311's Avatar
i'm using a cts pan ..most use f-body pans
