Lexus IS300 + LS1 = Drift Machine!
Old Jan 1, 2011 | 07:36 PM
Stancel's Avatar
Default LS3 Lexus IS300 drift, drag, autox, jack of all trades
New update 9/27/13 The Dry sump LS3 is almost ready to start.
Update: It is running and drifting! I missed my February deadline by several months.
I am in the beginning stages of my track car build. I removed the stock 2JZ engine and 5 speed transmission. I am aquiring the rest of the parts and hope to have it done by the end of February.
The parts list so far:
Engine choice has changed to LS1 and no longer going turbo
T56 out of a 2006 GTO
LS6 intake rails and injectors
GTO oil pan (being shipped right now)
Fbody Driveshaft
A million AN fittings
Fuel pressure regulator
Braided lines
2 walbro intank pumps
Here is how the car sits right now:
Action shot with the original engine:
Old Jan 1, 2011 | 08:23 PM
rotor vs. piston's Avatar
I would go ahead and send out the ECU to get reprogrammed so it's ready when you get to a point where you can start it.
Can't wait to see how this one turns out. Have fun and take your time.
Old Jan 1, 2011 | 08:46 PM
Stancel's Avatar
Yep, I will be getting the computer reprogramed soon. I wanna get my injectors and cam ironed out before I get it programed. I also need to find the pin outs so I can dive into the harness.
Old Jan 9, 2011 | 03:41 PM
Stancel's Avatar
small update:
My oil pan has been delivered.
I ordered 80lb injectors that should arrive this week.
Now I have a few questions:
1. Should I run the off the shelf cam they used in this month's CarCraft (link below) or go for a custom grind?
5.3 turbo build
2. Keep stock fuel rails or upgrade?
3. Which oil pump are you guys using?
4. Should I clearance the oil pan or hack up the crossmember? I am leaning toward chopping up the crossmember because this is a drift and track car so I need all the oil I can get.
Old Jan 9, 2011 | 06:02 PM
Irish350's Avatar
this is gonna be a clean *** swap..
ive had good luck w melling pumps, people also use ported ls6 pumps.
Id vote for a custom grind, takes a little longer and costs a little more but you can tell your grinder exactly what you have and want and youll be happy
aftermarket rails make the AN situation a little easier, since its just regular fittings not weird an/fuel rail fittings (i got mine from russell, didnt need aftermarket rails for my power goals)
I also got an improved racing baffle, but its for fbody pans..
Old Jan 9, 2011 | 07:18 PM
Stancel's Avatar
Thanks for the info Irish350. Anybody else have suggestions for my build?
Here is another picture of the car. There is no luxury left in the Lexus
Old Jan 9, 2011 | 08:14 PM
Irish350's Avatar
Thats fine, the only other flexus ive driven was an 01, so it was an auto w no armrest..
your setup looks more comfy, plus its a stick!
Old Jan 25, 2011 | 02:50 AM
ZTwentyAteU's Avatar
sweet! I've thought about doing this to my is300 a dozen times
Old Jan 25, 2011 | 07:28 PM
BlueMagicSS's Avatar
I want one of these so bad!!!
Old Jan 25, 2011 | 08:21 PM
Tig's Avatar
Tig
That is going to be one insane 300. Looks great so far, I like the cage. Any more shots of it?
Subd
Old Jan 25, 2011 | 08:55 PM
Stancel's Avatar
I have a few cellphone pictures from the owner of Essentially Offroad when they made the cage but I really need to take some better pictures. Yeah, a offroad shop made my cage but they fabricate stuff for everything from sweet luxury cars like my heap all the way to Baja competitors.
Here is a link to my photos:
http://www.flickr.com/photos/jstancel/
Update: I can't weld so I am having the GTO pan modified and also my crossmember. Hopefully the engine will be in the car soon. I also ordered all the same engine parts that were used in the CarCraft Junkyard 5.3 from this month's issue. I know I am a copycat...
Old Jan 25, 2011 | 09:06 PM
gnx7's Avatar
My 1st car in 1989 was an AE86 Corolla. The drifta wet dream.
This should be a fun project. If you think out of the box you can shave a lot of money on this project. A used '02-04 Z06 cam is perfect for turbo setups.
Old Jan 26, 2011 | 03:38 PM
Stancel's Avatar
Small update, I just got this picture of my halfway finished oil pan.
Old Jun 20, 2011 | 07:23 PM
Stancel's Avatar
So the car is running but not with a turbo or a 5.3. I found a deal I could not pass up on an LS1 with heads and cam. The car was put together in a week and a half for the drift event on 6-18-11. The exhaust and wiring a temporary but functional. Here are some pics:
Old Jun 21, 2011 | 09:15 AM
1logote's Avatar
I love it
Old Jun 22, 2011 | 11:50 AM
Stancel's Avatar
I forgot to give specs on the engine:
LS1 with PRC stage 2.5 LS6 heads, LS6 intake, ported and polished TB, 42 lb injectors, pretty healthy cam, electric waterpump, and the only accessory on the engine is an alternator.
The only things holding me back right now on power is the tune and exhaust. I am running stock manifolds but I am having headers made and the tune was all wrong. It put down 398whp. We were in a rush to get it ready for the event and it was on the dyno with open manifolds at midnight on Friday. With the headers and the right tune I should hopefully be around 450whp.
Old Jun 27, 2011 | 10:48 AM
Stancel's Avatar
I found another action shot
Old Aug 23, 2011 | 01:13 PM
Stancel's Avatar
Shot of the new exhaust
Old Aug 23, 2011 | 01:29 PM
toxik iroc's Avatar
why not paint the floor or or like a spray in bed liner? would look allite better
Old Aug 23, 2011 | 04:10 PM
deatschwerks's Avatar
Time to change the badging to IS570.
