Stans 1968 camaro LS swap and other upgrades!
#223
tsnow,from this diagram it looks like pcv gos into drivers side valve cover and runs around to passenger side and straight back to throttle body on a ls6 intake.this is correct,wright?
![Name: 5d2050a4.jpg
Size: 20.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/671061d1501791986-stans-1968-camaro-ls-swap-other-upgrades-5d2050a4.jpg)
thanks to ls1how to
thanks to ls1how to
#225
Could you do me a favor? If so, I would like a closer pic of the fuse/relay setup your wiring harness has. The one I got with my rewire is ok but is sort of homemade looking. This guy that rewired my harness went to great pains to make the relay setup look good and I must say he has all of the wires equal length and zip tied together for a uniform look but he soldered on or crimped on spade connectors onto each wire rather than buy some relay pigtails and make it look proffesional. I have a little work to do to my harness before it is ready to be added on. I found a firewall grommet that is a two piece and simple to install. Check out Steves thread I sent it over there.
Looking good!!!! Keep up the good work hope to hear it soon.
PS: Thats a nice quilt you have there, your wife is going to be pissed!
#231
I put my computer under the front of the center console, below the radio. I sent the wires through a 2" gromet/hole in the firewall there. The computer is easy to access here if you ever need to take it our for modifications.
#236
or my other option is to relocate the battery to the trunk and mount it there.i could put a stainless cover to hide it!what you guys think?or you think im ok under passenger seat?
![Name: IMG_7928.jpg
Size: 79.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/671067d1501791986-stans-1968-camaro-ls-swap-other-upgrades-img_7928.jpg)
#237
In my opinion the under the seat is a good option. It looks good where you have it but to relocate the battery and run the heavy gauge wire from the back to the front sure is a lot of work and a lot of money. On top of that the battery will eventually corrode the inside of your trunk. I am thinking the firewall or the right side inner fender is where mine is going. If I knew it would stay dry I would mount it in the cowl of my hood. Make a cover that would close in the cowl induction that doubled as the PCM mount. Run the harness out of the back side where it wouldnt interfere with anything and be done. I did pick up a fuse block similar to the one you have. It has a main lug for a hot wire and everything is cleaner looking. I have 4 relay pigtails coming tomorrow to eliminate the 25 spade connectors my rewire guy crimped on. You may want to fire it up before you mount anything. Looking good BMf as usual!!!
