Transmission help
It's my understanding the GEN IV uses a E38 ECM that only controls the motor. The newer trans are controled by their own computer. I have found a rebuilt 2004 4L60 that was behind a 5.3 that's within budget.
How can I get this trans to work with my GEN IV motor?
Will I need the ECM out of the 2004 vehicle?
Or can I get a later model (2009) trans computer to make it work?
I've searched, but I can't find an answer.
That's my plans if I can't find a compatible 4l60. All this is going in a 1953 Chevy 210 hardtop. I'm leaning toward the carb and 700r4 for ease of getting it installed.
Do you have the harness for the motor? If so all you really need is the TCM and harness to the trans. And the manual valvebodys are a pain in the *** if you plan on driving it everyday as you'll have to shift it yourself.
I would keep the fuel injection.
Your motor is a Gen IV with a ECM and TCM. I believe IIR you can use the 4l60 with the right TCM tune. The only problem being the front speed senor isn't present in the 4l60. All the 2009 were 4l70 by then and had a fwd input VSS. So double check that it will work. Ask in the trans section.
