pedal compatibiity
Old Jun 6, 2011 | 12:47 PM
crosstraining's Avatar
Default pedal compatibiity
Along with my 2 injectors not pulsing, I am getting an accelerator pedal position system code (P1125). I have a 2006 Escalade LQ9 drive by wire. The pedal is from a 2006 Monte Carlo. I chose this because it is a smaller size. It has the same plug. I have a new TAC module for a 2006 Escalade & a new harness from TAC module to pedal from EFI connection.
I do not have any throttle response.
Does anyone know if the 06 Monte pedal is compatibe the an 06 truck setup?
Old Jun 6, 2011 | 03:04 PM
ModMuscle's Avatar
Well...I think you need to use the truck pedal. I have seen threads where the monte pedal is used but they switched some wires. I spoke to someone who built my harness and he was adamant that I had to use the pedal that came with the computer/TAC.
I do not know if the TBSS pedal is the same as a truck or not...I bought the pedal for the TBSS and had to cut it down to match the size of my Monte pedal. I need to make a bracket to then mount it to the car. Not terribly difficult but it does take more to mount that the Monte pedal.
Best of luck!
Old Jun 6, 2011 | 06:00 PM
Best of luck!
Thanks,
Looks like I'm shopping for an Escalade Pedal.
Old Jun 6, 2011 | 07:13 PM
71ANTICARB's Avatar
https://ls1tech.com/forums/conversio...-ss-pedal.html
Old Jun 6, 2011 | 07:54 PM
Is the 06 LQ9 a Gen3 or 4? If I switch to a 06 Monte Carlo TAC module will that work?
I can't find a 06 escalde accelerator pedal to buy. I don't have a p/n for GM parts & mostly what comes up on google is just for the accelerator pedal position sensor.
Thanks for all the help Anticarb, w/ this as well as with the injector issues.
Old Jun 7, 2011 | 03:17 AM
garys 68's Avatar
I bought an 02 escalade LQ9 pedal/sensor from the GM dealer for about $100. BTW 02-06 is GEN 3.
Old Jun 7, 2011 | 08:40 AM
71ANTICARB's Avatar
Not sure but could you put the escalade app on the Monte pedal.
Old Jun 14, 2011 | 02:40 PM
Does anyone know where I can find a 2006 Escalade accelerator pedel or accelerater pedal sensor? It may come all in one piece. I can find up to 2005 & 2007 & up. Was 2006 a bastard year?
Thanks
Old Jun 14, 2011 | 03:32 PM
garys 68's Avatar
Rock Auto lists 02-06 non-adjustable pedals the same. $129 for pedal/sensor.
Or I've got a new 02 Escalade pedal/sensor (non adustable in my garage) if you want to try it.
Old Jun 14, 2011 | 04:53 PM
Thanks Gary. That is a little pricey compared to other years. I will likely get it though. I am getting a accelerator pedal system code, and I want the exact year/model that is for my engine/computer. I have a Monte Carlo pedal that fits the plug, but it does not seem to be working.
Old Jun 20, 2011 | 07:33 PM
Gary, have you seen that pedal any where else? Rock Auto sent me this:
Part #: 5S11464
Part Status: Back-ordered (Canceled - Please check back at a later date)
* There are no alternates available at this time and no ETA is available.
I don't think the the 02 pedal will work. I have an 04, but it is a 10 pin. I need a newer 6 pin.
Old Jun 21, 2011 | 04:34 AM
garys 68's Avatar
I got mine from the dealer for about the same price.
Old Jun 26, 2011 | 08:24 PM
Gary do have the part #? Then I can buy it from Gm parts direct.
Old Jun 26, 2011 | 10:45 PM
SickF85's Avatar
You can always check with John at Speartech. He provides everything you need for your swap and is always very helpful. Former GM electrical engineer, very savvy guy.
http://www.speartech.com/
Old Jul 10, 2011 | 05:07 PM
Thanks, John @ Speartech is an 1 1/2 hour drive away. I picked up a new correct truck pedal & new TAC harness & now the car runs.
