going to the dark side *engine is in*
Old Aug 31, 2011 | 12:18 PM
  #301
97badass's Avatar
i googled them this morning, from what other people were saying, down low they flow the same but up top you lose a little bit comparred to ls3/l99/l92 heads. assembled they cost more than ls3 heads but bare they are cheaper! wtf?
Old Aug 31, 2011 | 03:12 PM
  #302
1961ba427's Avatar
IDK what the deal is. The intake valves are super cheap comparatively too. Full list on them is only $7.98 each.
It does look like the heads and valves are backordered right now, but if you know someone in parts at your local dealership...he can work around that for the most part using GM's "**** case" system for expediting parts for downed vehicles.
Also forgot to mention...the LSA has been in use since 2009 in the CTS and now is in the 2012 Camaro lineup too. It's a detuned LS9 for the most part.
Old Aug 31, 2011 | 05:56 PM
  #303
97badass's Avatar
ls9 heads are crazy expensive!!! the scrap man said he was going to try to come over tonight and buy some scrap!! 11 aluminum wheels, 2 cars, 1k pounds of tin, 6 bare aluminum heads, 75 more pounds of aluminum, brass radiator, and 2 cats... any guesses?
Old Aug 31, 2011 | 07:48 PM
  #304
97badass's Avatar
the part number gmpartsdirect comes up with is 12610716
does that sound right to you? total cost shipped is $394.xx
Old Sep 1, 2011 | 11:06 PM
  #305
97badass's Avatar
im going to pass on the lsa heads, the combustion chambers are too big for my n/a lq4 75cc vs. 72cc on the ls3 heads. pace performance has the bare ls3 heads listed for 329 each... or fully assembled for $314 i will be ordering them hopefully next week!
Old Sep 2, 2011 | 09:22 AM
  #306
1961ba427's Avatar
That is the part number I have, but full list is showing at only $272.89 each.
I'm not sure about the combustion chamber cc's. I had heard they were the same as LS3/L92's, but there is alot of misinformation I guess.
$314 each for assembled LS3's sounds pretty good to me.
Old Sep 2, 2011 | 12:31 PM
  #307
97badass's Avatar
yeah i bought a l92 head today now i need to find one more!
Old Sep 2, 2011 | 10:33 PM
  #308
97badass's Avatar
gm wanted $7 for that o ring on the oil pickup tube, is it safe to use a generic o ring from a multi pack? or am i stuck with paying way too much for it?
Old Sep 2, 2011 | 11:14 PM
  #309
1961ba427's Avatar
If it were anywhere else I'd say chance it. I still think you'd be fine, but I personally wouldn't wanna risk having a sealing problem in that location.
Question for Merv and other LS familiars that read this.....I can get ahold of a 4.8 that has low miles, NEW LS7 lifters, new stock cam, good compression, but has very low oil pressure for $300. It's from oil pan to valley cover. No accesories, intake, or coils. It was replaced under warranty when it continued to have oil psi issues. Should I just pass??
Old Sep 2, 2011 | 11:45 PM
  #310
97badass's Avatar
yeah im worried about it... i know i grabbed the other one when i bought the car pan, but i cant find the damn thing. low oil pressure sounds like either a cam bearing spun (worst case) or oil pump is junk.
Old Sep 2, 2011 | 11:48 PM
  #311
1961ba427's Avatar
Since I know the rest of the motor is healthy...head gaskets and bolts are brand new...I'm thinking about buying it and just pulling the bottom end maybe?? If I could patch it up without having to buy head gaskets and bolts I could come out decent. Maybe use it awhile then swap in a bigger longblock later. IDK
Old Sep 3, 2011 | 06:49 AM
  #312
97badass's Avatar
only other easy fix for low oil pressure is a **** ton of sludge.
Old Sep 3, 2011 | 09:25 AM
  #313
93Z2871805's Avatar
Veteran: Air Force
I'd walk away from it honestly, I can get a good running aluminum 5.3 (LM7?) for $350 locally.
Old Sep 3, 2011 | 12:43 PM
  #314
the_merv's Avatar
Veteran: Air Force
LM7 is the Iron 5.3l. I'd walk away from anything with low oil pressure.
Old Sep 3, 2011 | 12:58 PM
  #315
merim123's Avatar
i have no idea where you guys are getting these motors so cheap. even if I search the entire US via car-part, you can't get a 5.3 motor that cheap. Aluminum l33s are 1k
Old Sep 3, 2011 | 01:03 PM
  #316
93Z2871805's Avatar
Veteran: Air Force
Local classified ads are where I'm seeing them. I'm thinking about going to pick that 5.3 up. Last winter my buddy an I picked up an LQ4 complete from TB to oil pan, harness and all with a 5 speed bolted to it, running for $250. Biggest steal ever.
Old Sep 3, 2011 | 05:47 PM
  #317
97badass's Avatar
i picked my 6.0 up for not much more than that 5.3...
Old Sep 4, 2011 | 10:42 PM
  #318
97badass's Avatar
little update guys, probably be my last for a few days... tomorrow morning im headed to wichita to pick up my k member and rack and pinion for $150
gonna let some cash build up while i do body work on the car and after i get some built up im going to finish the engine. all thats left is one head and my cam. im getting closer to being done but still probably half way since i cant find a transmission i dont have to drive 6 hours one way to get
Old Sep 5, 2011 | 10:42 PM
  #319
97badass's Avatar
couldnt help myself, i got the motor mounts, k member, rack and pinion, lca's, k member nuts in excellent shape, and the steering shaft for $120
Old Sep 6, 2011 | 04:18 PM
  #320
1961ba427's Avatar
I just looked at the head casting numbers out of curiosity and they are #243's. I didn't know GM put those on 4.8's??? Are they the same as LS2 #243 heads or do they have smaller valves? Wouldn't these make this engine worth getting?
