Radiatior over flowing?? after long trip?
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
I have a LQ9 in my Lexus SC300,
I have a LS1 water pump with water pump spacers, no heater (u shaped hose connecting the 2 heater hose outputs).
i have a 28x16x3 radiator with a 14" silicone intakes fan that runs all the time.
after i drive the car some what hard for a trip like i drove for about 3 hours, and when i went to the flash light drags and hot lapped it for a while.
when i shut it off about a gallon of coolant spits out of my over flow tank, and by the time its cool enough for me to inspect what happened, the over flow which i would say is 3/4 of a gallon is totally empty, and about 2 inches of water is missing from the rad.
Is there something im doing wrong. the sending unit for my gauges say 185ish degrees. and the motor is working perfect
any ideas or suggestions would be appriciated
thanks
thanks
thanks
thanks
no the cap is fine, i am using the stock lexus over flow is it possible its too small?
the line that goes from the tank to the rad might be the problem i dont think i clamped it "tight"
to the rad
to the rad
Hmm i know the system needs to be able to hold the pressure to maintain cooling, but if it remains cool and still overflows. Thats different
im not really sure, i do know that before i took it to get tuned i added about half a gallon, then i cam home after driving hour and a half up and back and tuning it.
and as soon as i got home it went burble burble, psshhhhhhh
and dumped about a half gallon on the floor
I agree with "the_merv" above. I am pretty new to LSx motors but this is a really common issue with Porsche Boxsters, and 996. The problem in them is always related to bleeding air out of the system. On the Porsche's there is a very specific process to go through to bleed the air out of the system. For the LSx I have not seen similar instructions but I have found that the vent tubes on the engine are designed to allow the highpoint in the system to bleed air into the radiator. If you are tapping into the water pump you may have a high point in the engine that is holding air. This will be particularly true if the coolant in the heads is at a higher point then your radiator.
