Is DBW setup wirth it?
Old Jan 17, 2012 | 09:54 PM
LS1 pwrd NOVA's Avatar
Default Is DBW setup wirth it?
I found an 04 yukon 5.3 dbw complete pull out motor only with everything for $450 & has 98k miles. But is dbw worth it? Give me the negatives on this setup. Or any positives if theres any.
Old Jan 17, 2012 | 10:14 PM
FastKat's Avatar
Positives:
*No throttle cable to run - only wires, which are much easier
*Hooking up cruise control is really easy
*Big cool-factor
Negatives:
*To save yourself a headache, get everything you need from the car - PCM, throttle body, TAC module, pedal, and wiring harnesses (especially TAC to pedal) otherwise, you can have compatibility problems if you mix and match parts
*Must be able to run a bundle of wires from the pedal through the firewall
Old Jan 18, 2012 | 06:52 AM
psiconversion's Avatar
LS1Tech Sponsor
Agree with FastKat with exception of the wires through the firewall. Certain Standalone harnesses position the PCM under the dash so therefore you dont have to route the pedal wires through the firewall. Also, since you are going with a truck setup, the truck TAC Module and Pedal are more readily available. We have the entire setup for $200.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jan 18, 2012 | 07:18 AM
98SuperchargedLs1's Avatar
i have dbw in my 65 chevelle and love it.
Old Jan 18, 2012 | 08:58 AM
V8Rumble's Avatar
I'm sticking with DBW on my swap also. The one thing that you have to be aware of is that GM has apparently implemented a bit of a "delay" when going to WOT (probably for warranty/reliability issues), that can be removed when your tune is done.
Old Jan 18, 2012 | 12:30 PM
aknovaman's Avatar
Works great for vette guys
Old Jan 18, 2012 | 08:50 PM
Great info guys, thanks now let me see if i can still get it.
Old Jan 19, 2012 | 05:52 AM
oldgoat69's Avatar
Woks great for my situation, very smooth action.
Old Jan 19, 2012 | 02:13 PM
1976CamaroGuy's Avatar
I have a 2004 5.3 DBW that came out of gmc pickup, Everything is matched and original out of the truck (Tac, pedal, throttle body, and harness)
How "easy" is hooking up cruise? Anything under dash I might need? Like a convertor box that the cruise switch plugs into?
I am wanting to add cruise to to my 76 camaro and found a website that shows how to convert a 3 wire (stock cruise switch) to a 4 wire needed for the newer cruise set up
Just curious where that will plug into??
Sorry to hi-jack the thread BTW
Old Jan 19, 2012 | 03:41 PM
Hey good hijack question though. I'd like to know also.
Another question, what is TAC? You guys keep saying that. I'm trying to get everything for the dbw swap.
Old Jan 19, 2012 | 05:55 PM
John510's Avatar
Call Jon at PSI..... he has a kit you can buy
Old Jan 19, 2012 | 05:58 PM
FastKat's Avatar
Alright, so the DBW (Drive By Wire) setup has a few components:
1) PCM - Powertrain Control Module
2) Pedal - gas pedal
3) TAC - Throttle Actuator Control module
4) Harness from pedal to TAC
5) DBW throttle body
The TAC Module is a black computer box a little bigger than a deck of cards. It should have two plugs: one that connects to the engine wiring harness, and a second plug that connects directly to the gas pedal. Make sure you get all this stuff when you get your engine!
Also, regarding cruise control, you need to hookup your current cruise control switches and buttons from your car directly to the TAC module. You will need a wiring diagram for your vehicle and for the PCM to figure out what goes where.
Old Jan 19, 2012 | 08:12 PM
LS1Tech Sponsor
With DBW, the cruise wires will come from the TAC module and connect to your cruise control handle as stated above.
TAC stands for Throttle Actuator Control. In Gen III engines, the TAC controlled the Throttle Body based on pedal input and various engine information. As stated, we have the truck stuff in stock. Corvette stuff, however, is getting harder and harder to come by as GM has put production on hold. We are currently working on an alternative to the Corvette setup that IS available and will reduce cost. Keep in mind that the Pedal, TAC, TB, and PCM dont need to come from the same vehicle, although we always recommend trying to get them if you get a pull out engine. But they do need to match. So, if you have a truck setup, you need to run a truck tune. If you have a car setup, you need to run a car tune. Hope this helps.
Jon
PSI
__________________
Ebay Store
Old Jan 19, 2012 | 09:15 PM
Cool info, ill grab it all from the truck.
Old Jan 20, 2012 | 08:13 AM
aknovaman's Avatar
These tell you how to connect cruise:
https://ls1tech.com/forums/conversio...wire-swap.html
http://67-72chevytrucks.com/vboard/s...d.php?t=398006
http://67-72chevytrucks.com/vboard/s...ght=DBW+cruise
Old Jan 20, 2012 | 09:20 AM
garys 68's Avatar
Cruise and DBW are pretty easy to hook up if you're using a trans with electronic speedo output. Also, stock GM controls will work, not ford, mopar, etc. The Dakota Digital aftermarket stalk will not work, but their dash mounted controls will.
Info
http://www.lt1swap.com/2000harness.htm
http://chevythunder.com/drive_by_wir...erator%20pedal
