79 LQ4 Caprice
Old Jul 16, 2012 | 09:53 AM
  #41
87caprice318's Avatar
Thanks for your PM and ok I understand now. I figured you were trying to accomplish something different by cutting your floor, lol..But nice work you've done to it. #SALUTE
Old Jul 17, 2012 | 11:18 PM
  #42
spearwarrior's Avatar
subscribed
Old Jul 28, 2012 | 01:07 AM
  #43
darren roar's Avatar
the past couple nites in the garage have been awesome. ive got a bunch of little stuff done that is amounting to alot. hopefully pics will follow. i got a little excited because i got to turn the motor over with the key.
Old Aug 4, 2012 | 12:26 PM
  #44
well, i got 95% of the wiring done and got my seats in place. the only thing left is the gauges and i learned that relays r your friend. its all down to the small stuff hoses and a small fuel leak. the only major thing now is exhaust, interior and a driveshaft.
Old Aug 12, 2012 | 11:20 PM
  #45
gettin closer everyday now. its down to the exhaust and i can start her up. nothing changes the look of a car like wheels so i got her a set of 17x8 N90's. i think a good look would be painting the bumpers to match but we will burn that bridge when we get there. i know they take your eyes off that cancer, lol.
Old Aug 25, 2012 | 01:33 PM
  #46
still making great progress and saved some dough. minus my gauges the car is wired, i had a small fuel leak which can be scratched off the list along with trimming more of the trans tunnel. mounted all my sending units and ordered my exhaust. waking up to a delivery on your porch always makes your day better.
Old Aug 27, 2012 | 09:41 PM
  #47
ihavetoomuchstuffman's Avatar
What headers did you use? I tried to use the stock 5.3l headers but on the drivers side it runs right into the brake proportionate valve. The passenger side seems to work fine with the f body camaro manifold.
Old Aug 27, 2012 | 10:09 PM
  #48
Good stuff bro...what did u do about your fuel pump? Did u drop the tank and put hose in there to suck gas from bottom of tank???
Old Sep 1, 2012 | 11:39 AM
  #49
thank ya guys shes getting ther slowly but surely. i bought a 37 degree flaring tool and cut off the barb on my sending unit and used a tube nut and sleeve. my headers are hedmans the cheapest ones i could find for a 03 camaro. i think this is the same pair christine has, i cant recall if he had any problems or how he mounted his motor. the manifolds i had fit great it was more a matter of doing the exhaust only once. i think a 1/4'' out of the primary tubes on the pass side along with taking 2'' or 3'' from the collector they would fit even better. the drivers side just needs cut and a bend put in it to line up with the crossmember. i cant really complain considering how easy they go in and out, besides who would ever figure an 03 camaro could be wider in any way than a 79 caprice. lol.
Old Sep 1, 2012 | 12:53 PM
  #50
aknovaman's Avatar
When I made Christine engine mounts, Since there is a ton of oom on driver side, I shifted the engine to the driver side so the tube would clear the pass lower a-arm by 1/4 or more inches. I used urethane motor mounts so I knew it would not shift when racing. Looks like you heated the tube close to the frame.
Old Sep 1, 2012 | 04:14 PM
  #51
aw damn....I just dropped mine down....gotta put headers in and finish mounting up..so this header clearance...is that with all longtubes or certain ones?
Old Sep 1, 2012 | 09:56 PM
  #52
What did you do the the fuel system, Im having a few problems. The car runs for a few sec. rev up high and then shuts down. I have a post in the carb lsx section with video.
https://ls1tech.com/forums/carburete...ning-help.html
Old Sep 1, 2012 | 11:14 PM
  #53
About to respond in your thread
Old Sep 2, 2012 | 12:23 AM
  #54
The only problem I had was a small leak. Did u use a MAP sensor with yours, what pill did u use in your ignition box. I ran a -6 from the tank to the pump and to the carb, I also ran a new vent line. U might have a vacuum leak causing your idling problems. What fuel pump do u have?
Old Sep 2, 2012 | 07:33 AM
  #55
aknovaman's Avatar
Wink
Christine has same headers as your car.
Old Sep 2, 2012 | 05:59 PM
  #56
Your build looking good. Since my car was fuel injected i just capped off the return line and attached the fuel line to the carb. I plugged the map sensor in but I have to get an adapter to fit it in the intake. I capped off every vacuum so I could here it run that night. The exhaust isn't installed.
I think I have to get a fuel regulator, I hope my problem is just that too much gas is going into the carb.
Old Sep 2, 2012 | 09:03 PM
  #57
aknovaman's Avatar
TH400 did not need to cut trans tunnel but I did make a custom trans crossmember
Old Sep 2, 2012 | 09:34 PM
  #58
That 700 is longer and my angle was 10 or 15 degrees at the carb mount. How was christines motor placed.Your carb only needs 6-9 psi to run if u had to much pressure it wouldn't run. U can't go wrong with getting a regulator. The only problem I had was the leak, so far. That's not to say it will hit the fan later. The suggestion of the reluctor wheel could b the problem.
Old Sep 2, 2012 | 09:45 PM
  #59
aknovaman's Avatar
Wink
I did not take any detailed pics efore Henry came and got it, just the vid. Maybe I will get some better pics when I see him?
Old Sep 17, 2012 | 12:15 PM
  #60
still chuggin along. all the wiring is done. i got the drivers side header modified and i had my exhaust mocked up and fitting pretty good. fabbed a bracket for my gauges, im not sure if ill keep my tach were it is but it will do for now. i almost put the tach in the glovebox for a super secret squirrel deal, lol. still thinkin about how to deal with the passenger side header.
