Adding aftermarket fuse blocks to modded LS harness
Pretty much everything should be fused. most of the Ign Hot are 5 to 20amp fused. but you should check the spec's from the manuals.
But a few of the key ones:
Battery Hot 12+v (orange)
Ign Hot 12+v (Pink)
- coil
- Injectors
- auto Trans
- ODBII Port
Fuel Relay
Fans Relays
BC
Ign Hot 12+v (Pink)
- coil
- Injectors
- auto Trans
- ODBII Port
Fuel Relay
Fans Relays
BC
As for how to wire the circuits bczee pretty much laid it out. If you need a visual refer to the diagram in post #6, https://ls1tech.com/forums/conversio...-relay-no.html . I am doing something similar to this, but I am changing a few things which are unique to my build.
For my setup I went this route. If you want more details you can click on the link in my signature.
The UPS truck dropped off a package from Waytek. Now I have all the items and tools to create my fusepanel. I will be using a Cooper Bussman RTMR Panel 15303-6-2-4. This panel allows you to us up to 5 micro relays, ISO 280 footprint, and 10 mini-blade fuses. I also ordered a power relay module, an assortment of metri-pack 150 & 280 connectors, terminals & cable seals with the appropriate delphi crimpers. This should keep me busy for a bit.
The fusepanel is extremely compact and measures 4.25" x 3.4"
That is a power relay module. I am connecting my main power wire to it and it splits it into two fused circuits, one is battery and the other ignition. You can use up to a 70A fuse for each circuit. This will power my fuse panel and I can tap into for other things if needed in the future.
