Best oil pan for LSX in Caprice
What is the best oil pan to use when installing a LSX in a '89 Caprice? I have the stock truck oil pan on the engine now. Would try to avoid having to modify the pan or car, as I don't have good access to a welding machine. Is there a pan that will fit without mods? If the pan sits a little low, it doesn't matter that much, I'm used to german cars where the oil pan is the lowest point on the car..
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
What is the best oil pan to use when installing a LSX in a '89 Caprice? I have the stock truck oil pan on the engine now. Would try to avoid having to modify the pan or car, as I don't have good access to a welding machine. Is there a pan that will fit without mods? If the pan sits a little low, it doesn't matter that much, I'm used to german cars where the oil pan is the lowest point on the car.. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
