gas tank / fuel pump solution?
I'm going to be doing the vette works kit in the above post. Presently, my 2nd gen tank is sumped in the rear, with an external pump. The tanks inc is a popular kit with a lot of members.
Do I have to run new lines no matter what? This is a 4.8 with a cam.. nothing to serious as far as power goes.. stock injectors will be used as well
https://ls1tech.com/forums/conversio...get-build.html The factory in tank pump modules have check valves to keep fuel in the "can" and also the return from the regulator goes to the can. This keeps the pump supplied, but also covers the pump with fuel keeping it cooler and sometimes quieter. Most of the modules have pressure regulators built in, with an external you will need the Vette filter/regulator, or a regulator and return on the fuel rail. Your stock 3/8" lines will easily supply the 4.8
