T56 Hydraulics to 68 Camaro Pedal
I just finished everything up and went to test the car in gear on a lift, and the clutch pedal isn't fully engaging. The travel on the pedal feels really short.
I welded a small tab on the near the top of the clutch pedal (IIRC it was just above the muncie rod hole).
I'm not really sure what needs to be fixed, tons of people have done this and their pedal offered enough travel, I'm confused as to why my pedal is so short and unable to disengage the clutch...
Any thoughts?
Any thoughts?
Above Muncie hole = The Master has to travel a longer distance for same displacement
Below Muncie hole = The Master has to travel a shorter distance for same displacement
Because the pedal only travels so far. Is this right?
I bought the ebay one, same angle as the Speedtech bracket.
u just have to make sure it pedal is giving the master the full stroke.had that problem in mine.either buy the adjustable tick which I plan to do someday but right now I modified my stock got one with an adjustable heim on the end to adjust for full stroke I've had no problems.
Correct.
I Did the same as Burbalanche. I used a cutoff wheel to cut the original rod, then welded a hardware store threaded sleeve to it, then used a threaded heim to atach to the pedal. I used the factory Muncie hole.
how long have you had the tranny to the engine? Mine was together for a year. i have a 67 and thought i did not have enough travel but found my clutch and flywheel were stuck together. i fired it up in gear(on stands), pushed in the clutch ans slammed on brakes. small pop noise and now it works like a charm. just a thought.
i have one in my camaro 68 , went with the bracket like you have , maser an slave came from a 96 camaro , it was a very short push and very stiff , bought american powertrains versaion for 600 bucks its a "slight" improvement , very short and still very stiff
i think its the nature of the pedal geometry
